Results 1 to 15 of 21
Thread: TAILSTOCK- by request.
23rd Mar 2011, 11:04 PM #1.
- 6,458
The idea of this post is to try and discourage a trio of hopeful replicators and therefore avoid the laborious task of measuring and drawing the following rough copy of a Hercus 3 1/2 inch centre height dividing head tailstock I made a couple of years ago.
4E cast iron bar was used, 120mm dia x 75mm for the bracket and 80mm dia x 45mm for the body. I had Bohler Uddeholm partially cut through the bar for the bracket to facilitate my machining of the stepped back and the front cutaway. I can fit a maximum 6 inch diameter saw on the horizontal arbor of the Hercus mill which would not cut deep enough for some of the required cuts. My greatest problem was devising successful methods of securely positioning the work piece for each milling operation. I devised a lot of unsuccessful setups.
23rd Mar 2011, 11:15 PM #2.
- 6,458
More discouragement.
23rd Mar 2011, 11:51 PM #3Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Hi AB,
I'm not discouraged yet, what's next? Your machining finesse is only exceeded by your literary and photographic skills.
It's great to see a bloke who is willing to have a go. Well done, where's mine?
Just love that "Hercus green", and do you have designs for the Hercus dividing head. Gotta get one of those.
Ken
24th Mar 2011, 01:17 AM #4.
- 6,458
You trying to butter me up Kenneth?
The dividing head is different story. I procured a head casting from Hercus when they where ridding themselves of all the remaining No.O mill spare parts. That was about 4 years ago. I made up the remainder of the parts required to complete the head ( excluding the worm and worm wheel and, very fortunately, the three division plates ).
BT
24th Mar 2011, 07:58 AM #5Most Valued Member
- 4,255
24th Mar 2011, 09:54 AM #6Most Valued Member
Nice pictures Bob, you've already cost me money. When I cleaned my rotary table I put it back together with a "not so good" thrust bearing on the worm gear shaft, thinking that it wouldn't matter as long as I turned the table the right way the thrust would be on the other bearing. I didn't think about machining while the table wasn't locked. (I had been planning on replacing the bearing "one day")
I'd been thinking of fabracating one from plate, maybe you chould scare me off with the price of the cast blanks. Although I still enjoyed looking at the pictures.
24th Mar 2011, 10:20 AM #7Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Thanks for taking the time Bob. I'm interested in making a tailstock too, but I think it will be much simpler than yours.
24th Mar 2011, 01:34 PM #8.
- 6,458
"I'd been thinking of fabracating one from plate, maybe you chould scare me off with the price of the cast blanks. Although I still enjoyed looking at the pictures.
Stuart "
Stuart ,
Are you talking about the plane or the little tailstock? The tailstock was machined from bar not castings. The two pieces of bar might have cost me about $50 in total.
BT
24th Mar 2011, 02:26 PM #9Most Valued Member
Hi Bob,
Sorry I meant cast not casting. I must say I was expecting the pieces to cost much more than about $50. That doesn't even scare me away and I'm tight! lol
I'll have to scale mine up a bit as I need 6 1/6 inches. I wonder if yours with a 3inch block would be any less useful than a scaled up one?
24th Mar 2011, 02:54 PM #10Most Valued Member
- 4,255
is cast the best way to go..or would fabricating one from steel be better?
24th Mar 2011, 03:21 PM #11.
- 6,458
Bear in mind boys, my tailstock is convoluted be cause the original was.
The Hercus mill table is narrow with only a pair of tee slots ( on the old model ). The offset design suits the tee slot position. Accurate alignment is facilitated by means of a tee slot locating tongue in the underside of the base of both the head and tailstock.
I chose cast iron because it matched the original and because it is a pleasure to machine ( as long as you can cope with black filthy hands! ). I will draw the thing up then you lot can expand, contract, swell and deflate, or elongate it to your heart's content.
BTLast edited by Anorak Bob; 24th Mar 2011 at 03:42 PM. Reason: poor spelling
24th Mar 2011, 03:31 PM #12Most Valued Member
24th Mar 2011, 03:31 PM #13Dave J Guest
Fabricated would work as well, the thing with cast iron is it dampens vibration better.
For a tail stock I am not sure if it would matter.
Stuart,
You can always use you lathe tail stock on a riser block with your rotary table. It will be more useful than a commercial bought one because it has a MT3 taper where the bought one just has a strait shaft.
Dave
24th Mar 2011, 03:34 PM #14Most Valued Member
24th Mar 2011, 03:54 PM #15.
- 6,458
Am I seeing this starting to veer away from the need for drawings?
Tailstock DRO
By Stustoys in forum METALWORK GENERALReplies: 58Last Post: 11th May 2011, 01:15 PM -
Indexing the tailstock on a 260
By jackafrica in forum THE HERCUS AREAReplies: 0Last Post: 13th Oct 2009, 07:25 PM -
Tailstock Turret
By Big Shed in forum METALWORK GENERALReplies: 36Last Post: 9th Jul 2009, 07:40 PM
