Results 1 to 5 of 5
Thread: A bit down in the mouth
19th Mar 2011, 09:44 PM #1Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Feeling a bit crappy after today's session, but I have the cure.
Order some more tooling from CTC Tools.
I spotted this post recently on the Home Shop Machinist formum. The author of the post had this to say.
"This is by far the best indexable mill I have tried and it has subsequently become my go-to mill for facing and rough milling as it effortlessly removes several millimeters of steel in a single pass and with an excellent finish".
He was describing a 45 degree indexable milling cutter from CTC Tools.
The best indexable mill I have tried(so far). - The Home Shop Machinist & Machinist's Workshop Magazine's BBS
I've checked the prices, $16.75 for the cutter head and $29.75 for 10 inserts. All up less than $70 including postage.
Before I order one, have you guys had any experience with this item?
Ken
19th Mar 2011, 10:03 PM #2Dave J Guest
I have had one for a few years but have only used it to knock the corners off things to a 45 degree. It works great for that, haven't tried to use it as a face mill like in that thread.
Dave
19th Mar 2011, 11:57 PM #3Product designer retired
- Nov 2006
- 79
- 2,074
Hi Dave,
If you get a chance, would you be prepared to try it out as a face mill. In fact, go and try it now while the kettle's on, we can wait. I reckon it would really rip into aluminium.
If it works, the only disadvantage I can see is not being able to machine up to a shoulder.
Ken
20th Mar 2011, 11:42 AM #4Dave J Guest
On the thread in your link they say they are great to use for a roughing face mill taking off several mm in one cut.
Dave
20th Mar 2011, 09:46 PM #5Golden Member
- Apr 2009
- Ballina N.S.W.
- 644
neksmerj
Ken, I have the 32mm version of the CTC tool and mostly use it for chamfering edges. I have used it for facing on steel and aluminium as well, it does a pretty good job and leaves a good finish. You can obtain a better finish with a single tooth cutter eg fly cutter.
Bob
bitter taste in mouth
By Tiger in forum WELDINGReplies: 5Last Post: 4th Aug 2009, 10:37 PM
