Results 16 to 30 of 58
Thread: Best metal work vice
19th Feb 2011, 09:40 PM #16Pink 10EE owner
- 6,218
19th Feb 2011, 09:43 PM #17
The old Dawn 6" Offset engineers vice are rather heavy, some 55Kg, so not exactly movable. Mine is bolted to a bench next to the Fidax cast iron bench Drill Press. Attached is how the shed use to be, before the new shed took all the turning stuff . . . I don't work metal much, but I know I can cut, bash, grind securely with the Dawn.
Pat
Work is a necessary evil to be avoided. Mark Twain
19th Feb 2011, 09:58 PM #18Most Valued Member
- Oct 2007
- 3,112
Of course you would instil upon your students, as mine did seemingly endlessly, that it's a vice and not an anvil Naturally back then the "advice" was accompanied with a clip across the back of the head for having to remind us seemingly endlessly
Grahame beat me to it, for a welding bench I'd try to have it removable. I have a small bench on wheels and made sure the top is both flat, has accurate 90 degree corners (so I can use it as a jig), and most of all is free from obstructions so I can slide my work around. Even my TIG torch holder is a recycled little C clamp, and I often move that out of the way.
Pete
19th Feb 2011, 10:00 PM #19Dave J Guest
That Dawn vise looks like the one I got rid of 25 years ago.
That is a good design and well built vise. I bet his dad was happy.
Dave
20th Feb 2011, 07:34 PM #20Member
- May 2010
- tasmania
- 96
Carter "semi steel" vice
My old farm shed came ready equipped with two (one a 4 inch and one 5) vices on a heavily used hardwood bench.
They are cast and marked "carter semi steel"
What does that mean? Are they cast steel? Cast iron?
Obv Carter is the manufacturer.
There is also a fabricated 6 inch offset vice near the door that is used for welding and low-finesse work. It is not quite parallel but is good at what it does!
20th Feb 2011, 10:29 PM #21
Carter was an Aussie maufacturer that started during WW2 to overcome the need to use imported tools. Semi steel I am just about certain would be the treatment the received (or didn't in this case) to make it suitable for casting.Hang on to it ,it will be a good un.
Its definately steel but not fully killed (de-oxidised) - something about the partial deoxidising being better to control mould shrinkage.You won't break it like cast iron and it will take an aful lot of mistreatment to even bend it.
20th Feb 2011, 10:30 PM #22
Dave J.
The lad had already made his own std vice when dad saw it and said he would like a bigger one as he always had trouble with holding the larger parts from the truck when doing repairs.
The kid made a bloody good job of it using some DAWN vice jaws and painted it a charcoal finish-the type with the pitts and wrinkles in it.
If it was a tad larger he might of got an engine block in it-LOL
Father and son nutted out the dimensions and supplied the materials & parts.I helped with little details like chasing a better grade of steel for the handle and thread as they are both big buggers and I could well imagine a length of 1200L pipe being slipped over the vice tommy bar handle.
23rd Mar 2011, 01:45 PM #23Member: Blue and white apron brigade
Just to round this thread out, thanks to Dingo Dog I manage to pick up a free Fabricated Dawn vice. It has no jaws but it has been recommended to me not to use the standard case hardened steel ones anyway but to make some mild steel ones instead. SO this should be easy enough to do.
BTW When I looked up what these Dawn fabricated vices cost new I nearly fell off my chair.
24th Mar 2011, 12:17 AM #24
24th Mar 2011, 07:56 PM #25Senior Member
- Sep 2008
- Queensland
- 445
29th Mar 2011, 05:17 PM #26Member: Blue and white apron brigade
I really like the idea of the demountable vice and using a HR connection.
So I scrounged a couple of pieces each of 75 x 75 x 5 and 65 x 65 x 5 SHS and with a bit of ironmongery I reckon I can get the smaller to slide into the large one with a fair fit. Now I have to connect the vice to the smaller piece and have it sit flush on the table.
The plan is to have the 75 x 75 welded into the frame of the table (blue) while the 65 x 65 piece is attached to the vice body (green) via an adapter plate A (grey). The vice on the 65 x 65 is slid into place and will be held in place with a couple of 3/4" or 1/2 locking bolts. Orange patches and strips represent welds.
I have 2 or maybe 3 plans and variants thereof.
Which of the following would be the strongest.
Attachment 165674
Plan A will probably be easier but harder to get a strong weld inside the gap connecting plates A and C.
Plan B has a vertical plate B that forms a T-piece with plate A. Because B is a through piece it can be welded top to Plate A and bottom to the 65 x 65 so should be stronger than Plan A?
The blank is just a blank plate to leave the table top flat - it does not need to be that strong.
Comments, ideas?
29th Mar 2011, 05:28 PM #27Most Valued Member
Hi Bob
How big is your vice?
If its pretty big I can understand the horizontal tube.
But if its small (i.e. easy enough to lift) why not have the tube vertical?
29th Mar 2011, 10:24 PM #28Member: Blue and white apron brigade
It's a 6" Dawn Fabricated offset vice, it weighs 25 kg and whether it likes it on not it's gonna get an occasional beating - but I do like the vertical idea - a lot less phaphphing about, especially If I attach the 75 x 75 direct to extra bench legs.
How about this?
Attachment 165715
Bench is going to be made from 75 x 38 x 1.2 SHS.
29th Mar 2011, 10:46 PM #29Most Valued Member
Well I like it a lot better, but then, I won't be the one lifting it.
Or are you going to cut the front off the 75mm tube so you can still slide it out forwards? If you aren't cutting the front off the 75mm tube I don't really see the need for the bolt, but I guess it cant hurt.
Just one other thing I would change, the welding of the 65mm tube to the plate under the vice. I'd bevel the top of the tube and the top of the plate so you get a nice big heavy weld around the top and not weld underneath. That way the plate will sit on the tube nicely.
29th Mar 2011, 11:12 PM #30Member: Blue and white apron brigade
Well my latest Chainsaw mill weighs 38 kg and this gets lifted on and off the long a dozen times when I mill a log so 30 kg is no big deal
SOLD: 6 inch metal working bench vice
By Sanity in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 28th Feb 2011, 03:18 PM -
looking for a metal work course after woodwork
By euphorbia in forum METALWORK GENERALReplies: 3Last Post: 28th May 2007, 06:28 PM -
How to make a metal vice
By Unit_01 in forum METALWORK GENERALReplies: 23Last Post: 26th May 2007, 09:11 PM
