Results 1 to 4 of 4
1st Feb 2011, 11:51 AM #1New Member
- Jan 2006
- N/A
- 7
Cross Pein or Tinning hammer for solid rivets.
Wood wright recently had a guest on TV that hammered some solid rivets.
I need to peen some 1/4" solid brass pins for some homade tools and solid steel rivets of the same diameter.
Do I need a Cross Pein hammer 32 oz or 40oz or a Tinners 12oz or 18 oz ?
1st Feb 2011, 12:08 PM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
Brass rivets being softer might do with a smaller weight than for the steel rivets.
Will you use a rivet set tool? What's the significance of cross pein? Wouldn't any hammer of suitable size do?
Jordan
1st Feb 2011, 12:37 PM #3New Member
- Jan 2006
- N/A
- 7
The guest said the straight wedge shape shapes the metal pin or rivet evenly and securely. A round ball pein offers less control, leaves many dents and a messy uneven surface.
I considering the estwing 18oz tinner's hammer or estwing E6-32 CP 32 oz cross pein. Other large cross pein hammers are heavy and named blacksmith hammers 2.5lb 4lb & 4.5lb
2nd Feb 2011, 04:28 PM #4Most Valued Member
- 4,255
you need a tinsmith's riveter...one that folds the rivet back down and makes a nice dome....else if its countersunk both sides first use a cross pein and then finish with the normal face (dad never used a ball pien......why not?....buggered if I know....just never seen him use a ball pien...he had plenty of them but never did I see him use one on a rivet...he was a tinsmith)
Rivets.
By RETIRED in forum METALWORK GENERALReplies: 5Last Post: 28th Jun 2008, 10:18 AM
