Results 1 to 5 of 5
Thread: Reducing size of bronze bushes
26th Jan 2011, 08:48 AM #1Member
- Mar 2008
- Nth Qld
- 68
I have some 16mm OD bronze bushes, 30mm long, ID 10 mm that I need to reduce to 5/8" OD. ( 15.875mm OD)
Can anyone please advise the best way to do this?regards,
Jill
26th Jan 2011, 08:55 AM #2Most Valued Member
- 4,890
Best way would be to mount on a Mandrel and machine them in a lathe.
If you are trying to find a method to reduce your Diameter without the use of machine tools and still retain a true diameter I think you will be hard pressed.
26th Jan 2011, 09:25 AM #3Pink 10EE owner
- 6,218
I concur with pipeclay, a mandrel on a lathe...
26th Jan 2011, 11:22 AM #4Most Valued Member
Hi
How many do you need to do?
How accurate do they need to be?(I'm assuming pretty accurate because you include the 0.005mm, but its 5/8 which I guess is what you are really after)
Do you have assess to a metal lathe?
26th Jan 2011, 12:16 PM #5
If they don't need to be super accurate, you can mount them in a wood lathe on slow RPM and file then linish them to size.
The secret to creativity is knowing how to hide your sources.
Albert Einstein
Source for Bronze billets
By Sebastiaan56 in forum METALWORK GENERALReplies: 12Last Post: 27th Jul 2009, 07:15 AM -
Bearing bronze
By Tiger in forum METALWORK GENERALReplies: 7Last Post: 31st May 2008, 05:52 PM -
worn bronze bushes
By burraboy in forum METALWORK GENERALReplies: 8Last Post: 16th Aug 2007, 07:41 AM
