Results 1 to 2 of 2
Thread: bench top for a bench grinder
24th Jan 2011, 12:09 PM #1Intermediate Member
- perth wa
- 42
i have built a bench out of pallet racking for a bench grinder. i have a welding bench and i just wanted to know what i should use for a bench top. i was thinking jarrah floor boards??
thanks alot!
tom/wodstok
24th Jan 2011, 03:04 PM #2
Tom..........if you are going to use a timber top, then I would recommend covering it with a sheet of gal iron or similar cut to size so you can easily wipe it down and not be worried about hot sparks and bits of metal digging into it...... I'm not as well sourced as you and used 2 sheets of 19mm mdf instead of jarrah on my grinding table.....it's flat, rigid enough but more importantly, cheaply replaced....it's the metal covering that takes the abuse and collects the grindings making it easy to brush them up when you are done grinding......nothing worse than leaving the shed to smell something; other than your overalls - still smouldering later on..........just a suggestion........Lee
Which 200 mm bench grinder should I buy ?
By Retromilling in forum METALWORK GENERALReplies: 15Last Post: 16th Oct 2008, 11:31 AM
