Results 1 to 7 of 7
8th Jan 2011, 06:25 PM #1.
- 6,459
Simple Lathe Tool Centre Height Gauge
I had been making a mounting stud for my tool grinder when something happened and the piece I was working on was relegated to the scrap box. A common occurrence.
It was only a piece of 1214 but I thought about it and decided to turn it into a gauge based loosely on one Hardinge make for their lathes. The mounting stud was just a cylinder with a wider flat base and that flat base would make for a stable gauge.
To adjust and then lock the gauge at the required height the grub screw in the base is loosened, the upper section screwed in or out as required then the grub screw is tightened. I recessed the inner base to facilitate lapping should the base get nicked.
The offset top allows also for the setting of rear mounted cut off blades.
Flame and sump oil coloured.
Bob.
8th Jan 2011, 11:53 PM #2Most Valued Member
Very nice Bob
I have to make one of these one day as well.(the list keeps getting longer........)
9th Jan 2011, 08:23 AM #3
14th Jan 2011, 12:21 PM #4.
- 6,459
Here's a link to the site and the tool that provided the inspiration for my gauge. It may be of interest.
Hardinge L-2A Tool Setting Gauge
Bob.
14th Jan 2011, 12:28 PM #5.
- 6,459
Here's the link to more of the website-
http://aafradio.org/garajmahal/tool_restoration.html
14th Jan 2011, 04:26 PM #6Most Valued Member
- Oct 2007
- 3,112
Excellent work Bob, I actually think your's is considerably better than the original.
14th Jan 2011, 05:17 PM #7.
- 6,459
Thanks for the kind words Pete.
You can be sure Hardinge would have made their gauge out of something a bit better than the 1214 I used. You've only got to look at the stuff and it rusts. It's only saving grace is it's ease to machine.
Bob.
