Results 1 to 15 of 17
Thread: lathe height
26th Aug 2010, 12:27 PM #1Most Valued Member
- 4,258
lathe height
I must be going bonkers...i thought I posted this yesterday...seniors moments come thick and fast some days
is there a standard way of determining the bench height for a metal lathe
I know its something to do with your elbows for a wood lathe ..but what about a metal lathes
I'm getting courageous and will need to make/borrow/beg or steal a bench/stand or what ever if I'm going to get it out of the box
26th Aug 2010, 01:31 PM #2
No standards as far as I'm aware. I made mine so that I have the cross-slide wheel slightly below elbow height (about 2") on the premise that that's the most used control on the lathe. On my 960B that leaves the 2nd most used controls (feed lever and half-nut lever) about 3-4" below elbow height.
I've done that with both my lathes and it seems to be the best compromise between too low - in which case you end up with backache - and too high in which case it's a pain to change chucks.
I also use a thick oil resistant rubber mat with perforations in it in front of the lathe, a lot easier on the feet in extended periods working and most of the swarf ends up down the holes and not on the bottom of my boots. This was a none-too-gentle suggestion from the keeper of the domestic funds after I tracked oily steel into the house one night.
26th Aug 2010, 01:53 PM #3Most Valued Member
- 4,258
26th Aug 2010, 01:59 PM #4Dave J Guest
You did post it up yesterday, it's in the HSS or carbide thread on post 71.
So it's not a seniors moment, lol
I have mine setup like Gavins, The cross feed handle is about 2 inch's below elbow height. I have read where people suggest elbow height, I think that would be to high for a 12x36 but might work on a smaller lathe with a lower centre height.
Dave
26th Aug 2010, 02:02 PM #5Most Valued Member
You did post it yesterday
http://www.woodworkforums.com/f65/ne...31/index5.html
"eskimo You don't normally do as much arm work with a metal lathe so I would say, the smaller the lathe the higher the bench(within reason), so that you aren't bending over it all the time."
26th Aug 2010, 02:23 PM #6Most Valued Member
- 4,258
26th Aug 2010, 06:28 PM #7
If I walked in to the house with oily boots, I would have a high pitched voice by now!
Boots are taken off in the laundry, whether I come in from the shed or from the property, tractor etc.
Agree about the rubber mat, slowly getting them in place in front of all the most used machines, metal lathe, mill, wood lathe, drill press etc.
26th Aug 2010, 07:15 PM #8Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Ergonomics
I went to buy some rubber matting the other day. I had a hell of a time finding anyone in a hardware shop with a clue about 'anti-fatigue matting'. Finally someone said Clark Rubber and it costs the earth. One of the bigger shops near me (Tru Value I think, used to be Home Hware) had a reasonable range of rubber matting, but not much idea. I settled for some fairly thin chequerplate stuff. It was 'only' about $36/m @ 1200 wide. I got a 2 metre strip to go between my lathe and bench. I think it helps a lot despite being thin, though I haven't done a long stretch at the lathe since. I was wary of thick stuff being a tripping hazard, aside from the cost.
I'm interested in views on the height issue also. I'm planning to modify my lathe stand so it can be bolted down as well as adjusted. I'll build in some more height too. I figure if I can operate all controls without stooping it's ok. As I'm nearly 6' 5", it needs to come up a fair bit. Maybe another 120, on top of the 150 it's already been blocked up. Must have been built by a dwarf. (No offence to short people. Their mothers love 'em. )
26th Aug 2010, 07:31 PM #9Most Valued Member
I find myself torn, a certain chain of stores sells Rubber floor mats 1530x920x12mm for $55. They do tend to pick up swarf very well, but they are comfy.
Or you could make yourself a duck board
http://www.housetohome.co.uk/imageBank/d/duck-board.jpg
not sure they would be as comfy.
26th Aug 2010, 07:59 PM #10
I use these, have a duckboard in front of the wood lathe and it has one of these on as well. They are very comfortable and insulates your feet from the cold concrete.
26th Aug 2010, 10:24 PM #11
Ok, here is a story, I went to Chandler markets here in Brisbane a while ago and bought 1 meter square x 12 mm thick rubber mats , made from recycled car tyres at $8.00 each, the other day I walked in one of the well known rubber stores and saw what looked exactly the same rubber mat for $79.95, I think some one is getting riped off, unfrikingbelivable.
26th Aug 2010, 11:00 PM #12Senior Member
- Sep 2007
- Newcastle NSW
- 77
- 155
Bryan,
I read a suggestion somewhere to put spacers between the lathe and the swarf tray to make it easier to remove the swarf (If you don't have a removable tray).
I wish I had read it before I set my lathe up, it's a mongrel to clean the swarf out. If you need to raise the lathe, that may be the best way to do it.
Regards,
Russell
26th Aug 2010, 11:23 PM #13Senior Member
- May 2010
- rural s.a.
- 120
Hi Bryan & all,
I'm still setting up my workshop (slowly, slowly) but the mats that I will probably use are the ones I have seen at Parramounts, (for south aussies). Last time I saw them they were $50.00 & fairly large. About 1200mm X 2400mm & were full of holes about 25mm in diam.
Ian.
26th Aug 2010, 11:34 PM #14
27th Aug 2010, 12:41 AM #15Dave J Guest
