Results 1 to 13 of 13
Thread: Corrugated Iron - History
24th Jul 2010, 07:33 PM #1Novice
- Dec 2008
- On the Murrumbidgee
- 19
My mother died recently and dad, who was a carpenter/builder of 50 years, died in 2001.
I'm in the process of clearing out the house and backyard.
I found 16 sheets of what looks exactly like corrugated iron roof sheeting. They're approximately 185 cm long by 80 cm wide and heavily galvanised.
Here's the thing. Each sheet is 2 mm thick and weighs 23 kg. I cannot lift 2 sheets. There is evidence of concrete splattered on many of the sheets.
Was it a product used for formwork (deep trenches maybe?) many years ago? Not intended for roofs..surely?
Graeme.
24th Jul 2010, 09:39 PM #2Novice
- Mango Hill
- 86
- 20
Graeme,
It is possible they were used as a shute to pour concrete. I have worked on houses years ago where the house was built on a steep block and when there were footings or slabs to be poured (I am talking pre concrete trucks and pumps here) and the sand, gravel and cement was delivered and left at street level. The concrete was mixed in a large mixer and poured down shutes of corrugated iron to where it had to go.
Another use was forming up bathroom and laundry floors but the sheets stayed there.
The sheets in those days were a much heavier grade than is used now.
No doubt others will have other suggestions.
Colin.
24th Jul 2010, 09:49 PM #3
you used to be able to get different thicknesses of corrugated iron.
www.carlweiss.com.au
Mobile Sawmilling & Logging Service
8" & 10" Lucas Mills, bobcat, 4wd tractor, 12 ton dozer, stihl saws.
24th Jul 2010, 10:32 PM #4Banned
- Otautahi , Te Wa'hi Pounamu ( The Mainland) , NZ
- 69
- 78
Here in NZ 50 or so years ago corrugated roofing iron ( actually rolled steel) was about 22 gauge. The sheets were about 7-8 feet long and 2'6" wide .
Much of it was imported from Aussie .
Sounds like the stuff you have there
24th Jul 2010, 11:58 PM #5Most Valued Member
- 70
- 1,513
Now that is the good old gal stuff. I'm fairly sure you will find that on a roof somewhere. I have heard, some of the modern (for want of a better word) colourbond stuff has a paint coating thicker than the metal itself.
Nev
25th Jul 2010, 01:23 AM #6
used to come in 6,8 or 10' lengths.
back when things were done right the first time. and made from real materials.
25th Jul 2010, 08:56 AM #7Banned
- 69
- 78
25th Jul 2010, 09:10 AM #8Pink 10EE owner
- 6,218
25th Jul 2010, 10:12 AM #9Senior Member
- Apr 2008
- 269
Thicker still
Those culverts under rail lines in the Pilbara that you can drive your car through are made out of 5mm rolled Galv sheets. The big bastards ones are made in sections and bolted together using big galv bolts, washers and nuts. It isn't roofing but it comes from the same design. Have seen smaller culverts rolled out of 3mm flat Galv sheet by a mobile factory mounted on the back of a semi for a rail line extension back in the late eighties. Impressive to watch it being done.
DD
25th Jul 2010, 10:20 AM #10Banned
- 69
- 78
1st Aug 2010, 11:10 AM #11Novice
- Dec 2008
- 19
Apologies for the tardy thanks. Thank you!
Cheers.
Graeme.
1st Aug 2010, 12:13 PM #12Banned
- 69
- 78
How about some more photos .
Ones with a view of the whole thing
1st Aug 2010, 06:29 PM #13Novice
- Mango Hill
- 86
- 20
cutting corrugated iron?
By Gags_17 in forum METALWORK GENERALReplies: 8Last Post: 17th Jul 2007, 09:36 AM
