Results 2,746 to 2,760 of 3016
Thread: Your latest project
27th Jan 2023, 11:41 PM #2746Senior Member
- Jun 2020
- Freo
- 68
- 141
shed portion of the house reno is complete so time for a break from that so first piece of the next project
My latest toy which will be very useful in this project.
Sorry its sideways. Don't know how to rotate it in this forumLast edited by Grahame Collins; 6th Feb 2023 at 09:21 PM. Reason: rotate pic
28th Jan 2023, 06:30 AM #2747
Hello Mike, Check out this link...
https://metalworkforums.com/f316/t20...sting-picturesBest Regards:
28th Jan 2023, 10:30 AM #2748Senior Member
- Jun 2020
- Freo
- 68
- 141
Tried that, see if the edit fixed it
It sure did
7th Feb 2023, 02:35 PM #2749Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
Prototype sorted, now to make about a dozen more
7th Feb 2023, 02:43 PM #2750
What are you making?
Did you press/punch form them?
Looks like someone machined a cap off a jam jar to me
7th Feb 2023, 02:57 PM #2751Most Valued Member
- Mar 2011
- 1,536
They are lids for jam jars, I made them out of pickled onion jar lids….
They are cover plates for pipes coming out of walls.
I made a die set to press the recess and then hammer form the edge return around a buck made from one of the failed experiments from making the dies. The hole is drilled 8.5mm to start and then punched through with a 7/8” QMax
7th Feb 2023, 04:30 PM #2752
Definitely makes sense now
8th Feb 2023, 07:18 PM #2753I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,270
Figuring out how to get this off here is apparently my latest project, after just quickly nipping over to Cheltenham and back today
Fortunately, I actually got the original manual AND original inspection sheet listing the results of the Schleslinger tests.
Unfortunately, after doing the drawing for the foundation, Manuel had a siesta, and neglected to mention exactly how one is supposed to sling the damn thing in order to get it on that foundation before they sent the manual off for print....
Actually LIFTING it isn't a problem, that's a 4ton car hoist it's sitting in between. Figuring out where to sling.... Yeah. Doesn't really have any protruding castings where the column meets the ram, so slinging it Elliot style doesn't seem like it will work.
Some thought best applied when I've had a nights sleep, I think.
8th Feb 2023, 09:08 PM #2754Golden Member
- May 2020
- Willowbank QLD
- 517
How did you get it on the trailer?
If you can't get it off I can come and and find away and return your trailer once I am done.
8th Feb 2023, 09:16 PM #2755I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,270
8th Feb 2023, 09:19 PM #2756Most Valued Member
- 5,942
9th Feb 2023, 05:58 PM #2757Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
Im a bit late to the party but i would pry it up and get slings underneath it. I hear you with old manuals not having lifting instructions, my bevel gear cutter is the worst, very top heavy and no lifting points, they must have assumed everyone would have a team of strong lads around to shift stuff.
9th Feb 2023, 06:21 PM #2758Most Valued Member
- 2,651
In the photo it looks like there might be threaded holes in the base to take lifting eyes.
Nice machine BTW - well done!!
9th Feb 2023, 06:25 PM #2759I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,270
I'm always leery of putting slings down low, in case the object manages to flip on it's side in the sling. I have seen things rotate inside chains and slings before...
Probably not so much an issue with something the shape of this machine (probably just me being overly cautious at the best of times), and indeed I was trial fitting slings under the gearbox and then under the table, with a view to using blocks of wood on the table held up to the underside of the ram. Two things put a stop to that, one that the table appears to be a bit glued in place (or there's a 5th locking lever I missed!), but more importantly I realised my cunning plan was doomed to fail, as I didn't actually have quite enough lift height out of the hoist arms.
Gravity and topography to the rescue! Will start a thread on this machine (and how I got it down!) sometime soon, mostly because there is next to NO information on these machines out there, even though the smaller version (Sacia L450E) was sometimes sold as an Atlas branded machine.
I guess at the time (1967 for this one) most machines just got rolled around on pipe. I'd speculate cranes probably weren't really that common (other than shops handling BIG work) until OHS started putting a stop to 'put your back into it'....
9th Feb 2023, 06:32 PM #2760I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,270
Just went and poked some of the grot out of the hole, and yep, threaded. I didn't even think to look, just assumed they'd be smooth bores.
Even if I had seen the threads, I would have thought 'jacking bolts', never would have occurred to me to use them as lifting points, and that would probably work brilliantly.
Where were you last night!
And thanks, I'm pretty pleased with it thus far. Initial impressions and the back story suggest that it's probably in better nick than than the photos suggest too, which I'll get into when I start a thread for it.
latest little project
