Results 2,671 to 2,685 of 3018
Thread: Your latest project
30th Nov 2021, 05:16 AM #2671Senior Member
- Apr 2019
- Finland
- 46
- 117
I made this square tube bender about two years ago.
Used it to make this referee's chair.
30th Nov 2021, 06:19 AM #2672China
- Dec 2005
- South Australia
- 1,656
That's pretty snazzy would love to see it's construction
30th Nov 2021, 06:32 AM #2673Senior Member
- Apr 2019
- Finland
- 46
- 117
Its basically just a pile of plates bolt together.
30th Nov 2021, 07:29 AM #2674
That design for bending RHS looks real good. Do you have some drawings you could share on the Forum? I have been going to make one for some time but haven't come across any details of one
Just do it!
Kind regards Rod
30th Nov 2021, 10:23 PM #2675Senior Member
- Apr 2019
- Finland
- 46
- 117
2nd Dec 2021, 09:16 PM #2676Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,185
Random steel things
1) Some random steel on a pallet on a nature strip:
I'm guessing the blue angle with holes in the middle are supports (feet?) for some racking. The red ones are a strange mystery. I might use them as hangers.
2) A new spanner. A member sold me a nice ER32 chuck/holder, but its spanner flats are about 41.8mm – wider than my regular adjustable spanner. My other ER32 holders have 36mm flats. Considered milling/grinding 3mm off each side, but decided a new spanner was best.
The only tool I had that would fit it is this old thing on the left:
but I did find a home-made spanner from L.J.D.'s skip bin that was close (41ish mm).
So, some quick precision milling:
I started with HSS, but it was just rubbing. This thing was actually hardened!
The side of my one and only carbide end mill did the job.
Interestingly, one original flat was straight, but the other one was a little angled, causing the tip of the spanner to be tighter than the back side.
3) Vintage engine guy is in a hurry to bore several Austin 7 engine blocks. He needs a few extra boring machine setting blocks (they hold 1/4" round carbide cutters, with a screw to set the depth), to easily go through 1st, 2nd and final cuts.
Wants them to be from good steel (hardened and ground). So, I look through the scrap. Nothing flat except bright mild, and some guillotine blades. The former won't harden, the latter is already hard
Try to temper the blades:
The one on the left was too thick to heat properly, and only half of the other one got soft, but that is enough to start with. Bandsaw a few little chunks off:
mount in vice on mill, and square up the cuts:
The samples on the left show the 5 holes and 3 threads I will have to machine.
Think about setting up for them, but decide to reduce thickness close to target size first.
Nearly 1mm milled off with sad old brazed carbide cutter that came with this RF30:
(although sadly, somehow, I took a bit too much off one – it is now 9 or 10thou undersize).
Set up for the first hole - the 1/4" for the cutter. An end stop on the side of the vice, and line up a 1/4" end mill in the sample's hole. Then lock table in position, and spot drill:
Then I drilled down at 1/4", and checked the location of the hole, corrected that, and used the 1/4 end mill to bore the bottom flat and the sides closer to size. But no photos, so that is a tale for another dayLast edited by nigelpearson; 2nd Dec 2021 at 09:31 PM. Reason: missing attachments
10th Dec 2021, 04:12 PM #2677Most Valued Member
- 4,255
Machinists hammers.
Made these to give away...have no idea how they will stand up
The steel was parkerised.
The recipients wont get any warranty iether...lol
10th Dec 2021, 05:34 PM #2678Most Valued Member
- 2,651
They look great !!
10th Dec 2021, 09:23 PM #2679Member: Blue and white apron brigade
- 7,183
One of the most useful spanners I have in my shed for use on machinery etc is this Eclipse wide mouth adjustable.
As well as a wide mouth, it has long, narrow jaws and gets into places that many other large spanners cannot.
This one is 300mm in length
I also have the smaller (150mm) version for my electronics bench - really useful for reaching into electronics enclosures for holding nuts on the backs of glands, switches etc.
Teh large one is also good for large plumbing fixtures.
11th Dec 2021, 01:11 PM #2680
Good morning BobL,
I whole heartedly agree with you.
I have a similar Eclipse adjustable spanner bought as one of a a set of three. It varies to yours as the jaws are fat where yours has slim jaws.
These spanners are of far better quality than the average ones, specifically being made to closer tolerances than many others.
The black satin chrome finish resists rust much better than the shiny chrome equivalent..
Believe it or not, in our area , a bright chromed spanner of lower quality, hung up on a shadow board and left for 12 months will show rust on its exposed side.
It is because the cheaper tools have a very thin coating of chrome.
I am impressed with the Eclipse shifta because even the plastic / rubber sleeve handle has lasted a decade and not yet decomposed into chewing gum .
Many of my other tools with handles of this similar type of materials have succumbed to the local climate or atmosphere and degraded into a sticky hard to remove gum.
I bought the set locally at McGinns which was a large tool, enginneering outfit and selling goods mainly serving the mining and sugar farming community sadly long gone and that is a shame .
So many these days can't recognise the difference between a good and lousy adjustable spanner.
It says to me that at the time of their manufacture ,Eclipse were applying and maintaining a high set of specification for these spanners.
Yes they cost a few bucks more but have borne the test of time really well and well justified those extra dollars spent.
11th Dec 2021, 02:24 PM #2681Golden Member
- Dec 2011
- 505
The Eclipse adjustable spanner having a well fitted moving jaw AND a millimetre scale can be very useful. The other day I was on a mate's moored boat with a little Yanmar diesel, helping him adjust the ancient prop shaft gland with mangled locknut that was dripping water fast. Unless the engine comes out this gland can only be reached with one arm outstretched, and seen with only one eye. Using his Eclipse wrench like the one shown by BobL I was able to measure the nut across what remains of the flats (about 55mm across), then reach in with a pre-adjusted pipe wrench and free up the locknut, so Eclipse saved the day for us, because even if I had taken a caliper it could not have been lined up and read to get the measurement, and too hard to adjust the pipe wrench in place (tried that). Admittedly not an every day situation, but we were so pleased to get a result.
Bill
1st Jan 2022, 06:43 PM #2682Intermediate Member
- Jul 2021
- Adelaide, South Australia
- 33
- 28
Soft jaws
Made myself and my Dad a set of soft jaws for our Record vices out of some left over 3/8" Aluminium plate I had. Cut them out with a hacksaw, filed them square, then drilled the mounting holes with Dad's drill press. Did some final fitting once they were mounted. Turned out alright; almost too nice to use them!
1st Jan 2022, 08:39 PM #2683
Hi GrandFooBar, Guys,
Happy New Year all !
Nice pictures, I hope you have made him a spare set !
I found that mine very rapidly became dented and malformed, particularly gripping screws and filing slots. Well I'm sure you know what I mean. Mine are are loose covers so I can remove them easily when not needed, when I remember to...Best Regards:
2nd Jan 2022, 09:32 AM #2684Most Valued Member
- 4,255
7th Feb 2022, 10:20 PM #2685Diamond Member
- Aug 2019
- 56
- 1,185
1) Finished up the "fake nails."
250 of the little ones, cut on a lathe with ground HSS for the profile, then drilled the back to fit a nail, and welded some nails in:
The 15 larger nail heads were a but more interesting. It was too much work to turn them out of solid, so I machine a die to press 3mm steel into, rough out a punch, and try in a 10tonne press:
A bit of tearing there. The bottom of the punch was too wide/flat, so refined that in the lathe. There was also a bit of a point in the bottom where I centre-drilled the die:
Applied a Dremel like tool to smooth that out:
Then cut some discs, and practice some pressing skills:
Of course, the back of these aren't flat enough, so machine a buck to press them into, and carefully turn them off:
Then they had big nails welded in the back. Some of them also had a texture/pattern Dremel'd into them.
The end result of many hours. Of course, they all needed to have a rusty patina:
2) Finished up the piston boring machine tool setting blocks.
Drill to 4.0, use a combined drill/tap (slowly) in the mill to start threading, and finish off by hand:
Same thing on the other side for the depth setting screw locks:
(a variety of configurations there for different cutting depths)
Then, trim some of the blocks to size, surface grind them to the same width:
and do some hardening. Most in oil, one in water:
3) Air blow nozzle repair.
One time when using it, the plastic protector on the blow nozzle went flying off, never to be seen again.
I grabbed an old moulded power plug, took the pins out, drilled through where the cord went, and shoved it on my nozzle:
4) Lathe knurling tool adaptation.
Old lathe tools are always way too big to fit in modern QCTP holders. Here is one beside my 16mm holder:
My neighbour needs to do some knurning fast. His holders accept 20mm. I need to quickly mill 9mm off. Clamping the thing was a challenge. Not parallel, and kept slipping:
5) Got some goodies from a friend:
Among them was an unfinished parallel. Cast i-beam style.
Looks like it was roughly milled, then hardened. Time to finish it:
but slow going. The steel keeps heating up, and then the wheel cuts too deep, digs in, burns.
Tomorrow's task.
latest little project
