Page 174 of 178 FirstFirst ... 74124164169170171172173174175176177178 LastLast
Results 2,596 to 2,610 of 2658
  1. #2596
    Dec 2013
    54
    1,212
    If I had a milling machine I probably wouldn't miss the slots Dave. I only use them for securing a Myford milling attachment or angle plate (and prior to today, for accumulating swarf).
    Your welcome to come over and use mine in Muswellbrook NSW.
    I've seen a tradesman machinist have a round column mill at home and do awesome work, no matter what anybody says they are a capible mill and not overly expensive used.
    Seems we both have something each other want, but I'm not trading my mill for for your crosslide, lol
    Nice work anyway mate, I bought kitchen plastic chopping boards to cover my mill T slots and table either side of the vice.
    Sent from my 5007U using Tapatalk
    Using Tapatalk
  2. #2597
    4,978
    These are printed with PLA, so I don't know how they will handle the Rapid Tap cutting fluid I use.
    Rotated pic (again). My iPhone was being held in the normal orienation when the pic was taken, so I can't understand why this happened. I see Russ had the same problem above. Surely this can be sorted out mods?
    Hi Chris, Guys,
    I've mentioned this a number of times on the forums, the pictures contain information inserted by the phone/camera what ever, that contains the orientation of the camera when the picture was taken ! This information is used by the forum software to orientate the picture according to the rotation of the camera when the picture was taken.
    This information called "EXIF" embedded in the picture must be removed so that it cannot be used to alter the rotation from that which you may have changed it to later. You must edit the picture and re-save it in order to remove the EXIF data ! Normally I crop the edges off a picture in order to do this. Afterwards you can rotate the picture as you like.
    As a side note, dash cams also insert information into the pictures/video's that they take. Depending upon sophistication of the cam it may also contain GPS location co-ordinates, time, date and sequence number in addition to the device serial number.
    HTH.
    NOTE to mods: This information could do with being made into a sticky !
  3. #2598
    Aug 2011
    4,596
    Those T slot fillers are a great idea!
    I also like Dave's idea of cutting boards over the surrounding T slots.
    All this time I've been perservering with the T slots filling up with swarf when I could have thrown some chopping boards on it!
    Such a simple thing to do. That's gunna happen in the next few days!
  4. #2599
    Aug 2011
    4,596
    Oh, I used to have issues with photo orientation as well, so much so that some members got grumpy with me!
  5. #2600
    Mar 2011
    Adelaide
    894
    I got a bit more sophisticated and bent some sheet ally.
    Which, since fitting the DRO to the back, doesnít sit properly flat anymore
  6. #2601
    Aug 2011
    4,596
    No one likes a show off! Your latest project
    But hey that's a great idea too. I got a folder too, I should consider that.
    Did I mention I got a folder?
  7. #2602
    Nov 2007
    melbourne australia
    2,866
    Quote Originally Posted by nigelpearson View Post
    P.S. I assume this is just to keep the slots clean?
    That's right Nigel.
  8. #2603
    Nov 2007
    melbourne australia
    2,866
    I know you have John. So has BobL. That doesn't make it any less annoying.
    As I mentioned, my phone was in the "normal" position when I took that picture.
    So here's the thing. The EXIF data is used by the phone to "remind" it which way the camera was orientated when the pic was taken. So, next time you look at the pic it will be orientated correctly. Apparently Tapatalk can read EXIF data and keep pictures orientated correctly. Ergo, the problem is NOT the camera or the user- it's the forum software. The iPhone must be the most common camera on the planet, by a country mile. I say fix the forum software, rather than expecting users to faff around with their pictures.
    Rant over...... for now.
  9. #2604
    4,978
    Hi Chris, Guys,
    I disagree !
    Unless the phone has the ability to know which way is up at the point when you take the picture, then the reference position is a fixed one in the camera/phone whatever. If you rotate the camera to take a picture then the fixed reference in the camera is rotated as well and stored in the EXIF data.
    Its not an issue that can be corrected by the forum software ! The forum software has no idea which way round your picture should be displayed, it is orientated only by using the EXIF data if it exists. This is why you should remove it and then your picture will be displayed as you intend.
  10. #2605
    Jul 2021
    Adelaide, South Australia
    31
    9
    I think you have it backwards BaronJ. The problem is that vBulletin strips the EXIF data from uploaded images. Download the images and check the EXIF data; there is none. This is a fairly sane default as some devices may embed stuff like GPS location in the EXIF data, which is probably not the kind of information most people would want to make available to any old member on a web forum. A quick search on the net suggests that there is a config setting that you can toggle to keep the EXIF data, but the previously mentioned "con" probably outweighs the "pro". It seems this stripping of EXIF data is a common complaint amongst vBulletin users and has been for some time.
  11. #2606
    Nov 2007
    melbourne australia
    2,866
    Unless the phone has the ability to know which way is up at the point when you take the picture.
    It does. iPhones have a 3-axis accelerometer built in.
  12. #2607
    Nov 2007
    melbourne australia
    2,866
    Quote Originally Posted by GrandFooBar View Post
    This is a fairly sane default as some devices may embed stuff like GPS location in the EXIF data, which is probably not the kind of information most people would want to make available to any old member on a web forum..
    So why canít vBulletin use the EXIF data to get the correct orientation for the photo, THEN strip the data before uploading it?
  13. #2608
    Jul 2021
    31
    9
    I don't think there is any technical reason they can't, they just don't. They're already using some sort of image library to generate reduced-resolution preview images. Apparently it can be fixed, if you're willing to modify vBulletin yourself: https://biztips.co/fix-rotated-image...vbulletin.html
  14. #2609
    4,978
    Thank you for your comments !
    I usually remove EXIF data before I post a picture, that way the picture remains the way I want it to display !
    If I don't do this and leave the EXIF data in place the picture gets rotated by the forum to match the camera's reference. So if I take a picture with the camera rotated 180 degrees the picture appears on the forum up side down ! But if I remove the EXIF data by editing and rotating the picture to the correct orientation before posting then the picture appears the correct way up.
    So to me, the logical thing to do in order to prevent the forum using the EXIF data and orientating the picture according to it, is to remove the EXIF data first ! Before posting.
    From following comments it seems that some forums treat pictures differently ! I can't comment about Iphones, since I don't have one.
  15. #2610
    Nov 2007
    melbourne australia
    2,866
    That's what I suspected. Thanks for clarifying.
  1. latest little project
    By wayno60 in forum WELDING
    Last Post: 12th Jul 2008, 03:40 PM
