Results 2,446 to 2,460 of 3020
Thread: Your latest project
15th Dec 2020, 07:48 PM #2446Senior Member
- Apr 2019
- Finland
- 46
- 117
RR-track anvil
Here is my latest build.
Took about 5 hours + 2 hours for polishing / finishing after paint was dry. Made from 54kg/m rr-track. Lenght 450mm
Video about making: https://youtu.be/ZxR-sRFAzYw
15th Dec 2020, 07:51 PM #2447
15th Dec 2020, 10:05 PM #2448Senior Member
- Apr 2019
- Finland
- 46
- 117
18th Dec 2020, 07:47 PM #2449Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
Missing tap-holder handle
Found a tap holder in the drawer which is missing one handle, thought I would spend a lazy hour or so turning up a new one:
What I did What it looked like Found some 8mm rod,
grabbed in the Hercus, knurled the end.
The only knurling tool I could find is very fine.
Nothing like the coarse original.IMG_1089.jpg Round off the end a little. IMG_1090.jpg Machine the inboard diameter.
This is to fit into the castingIMG_1091.jpg Transfer rod to the Hafco AL336,
because it has the parting tool,
and has enough gears to actually cut threads!IMG_1092.jpg OK. Now for the thread.
About 6mm diameter,
but thread gauges won't fit inside.
Nothing a grinder won't fixIMG_1094.jpg IMG_1095.jpg Seems to be 1.0mm pitch, but is left handed!
My only threading tool is an 11IR:
an inside cutter.
I usually cut threads away from the chuck.
This will be tricky. Grab rusty old rod, and practiceIMG_1096.jpg After much usage of fwd/rev/brake,
got my confidence up, and a workable thread.
Now for the real thing.
Start with the thing I hate, a groove to cut up to.
I'm lazy, create that with the threading pointIMG_1097.jpg After many start/stop/rev/cross-feed-fiddles,
a thread that the little block fits onto!
First mistake:
I wanted to make sure the whole thread was good,
so I faced the end off,
to let me screw the block all the way on...IMG_1098.jpg IMG_1099.jpg ...which meant once it poked into the casting,
only half the thread was being used
...but after further machining –
pushing the inboard diameter back –
And, after wasting nearly 2 hours repairing a $5 diecast tap handle, what did I learn?
- Even if it is as simple as this, a diagram might have helped.
- A lathe with a working brake makes tedious little thread cutting possible.
- I gotta find some more threading tools
18th Dec 2020, 10:33 PM #2450
At least you got one of the time consuming rountuit jobs done that we all have banked up, want to do some of mine, lol.
I have a few small broken jobs where I won't throw away, but I will probably never do like you have done unless I really need it, though I have all the time in the world for.
At least it's given you practice with left hand threads etc.
We all live and learn, no matter how small a project is.
I made 3 recessed boxes today for myself out of 75x50 RHS which ended up 70x112mm inside with a 25mmx3mm thick flange around each one.
By the time I cut everything out of a sheet with the grinder and bandsaw for the 75x50RHS, millied the flanges square inside and out, it took around 4 hours after straitening, welding, grinding and flap disking with rounding the corners etc.
In my head I thought a couple of hours max, lol. All this work for 3 limit switches in the ceiling.
I seem to always underestimate a jobs time, at at my age you would think I'd learn. It's bitten me a few times with quoting on paying jobs, my loss but there gain.Using Tapatalk
19th Dec 2020, 12:59 AM #2451
Hi Dave, Guys,
Don't you find that as you get older you tend to take more care over the work that you do !
I'm currently digging the grouting out from between the bathroom tiles, a job that should only take a day. Currently I'm into day three and finished, now to start and re-grout them.Best Regards:
19th Dec 2020, 04:07 PM #2452
Yeah, I even squared up the RHS ends on the mill just so I knew they where perfectly square so everything went to plan.
Then milling out the center of the flanges after the cutting disc for the same reason.
My wife thinks I'm crazy sometimes as I'll pick out a flaw in something I've made and need to fix it.
She will say who's going to see it in the shed, my reply me and it will drive me nuts everytime I look at it. LolUsing Tapatalk
19th Dec 2020, 10:08 PM #2453Most Valued Member
19th Dec 2020, 10:46 PM #2454
20th Dec 2020, 09:53 AM #2455
21st Dec 2020, 11:11 PM #2456Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Finally got around to making the anti-backlash gears I needed for a project, now I just have to find or make a pair of extension springs to connect the twoGearA.jpg
27th Dec 2020, 01:03 PM #2457Most Valued Member
File Handles
I made some London pattern handles for my files. I think they are really designed to go on chisels but they work great on files too. Very comfortable. I made them to the design shown, which I found on the web.
I started with a length of octagonal European beech 30mm across the flats. Roughed out three handles on the lathe using various tool shapes. All tools were mounted on the QCTP. No free-hand turning. It was very slow. An experienced woodturner with a wood lathe would have made these in a tenth of the time. Parted them off. Fitted SS ferrules. Drilled stepped holes to roughly match the tang of each chisel. Sanded them, then two coats of tung oil/poly/turps mix. Heated the tang to dull red and pushed the handle on. Removed the handle as soon as it hit full depth to prevent excessive burning of the wood. The tang on the square file went back on tight with just a light tap. The rectangular tangs on the other two files weren't as solid, so I epoxied them on.Chris
29th Dec 2020, 01:42 AM #2458
Hi Chris,
I like those handles ! Particularly the mass production technique.Best Regards:
4th Jan 2021, 08:22 PM #2459Most Valued Member
- Charlestown NSW
- 1,673
My latest addition to the machine light flock.
I had one of those desk magnifying lens with circular fluro light, arm assembly's that came out of a skip at work some time ago. It was missing the lens and the light fitting. I got it with the intention of making a machine light out of it.
So yesterday I decided to get into it. Dave J put me onto some cheap square LED work lights (very similar to these) on Ebay early last year and I bought four of them at the time.
I have one mounted above my lathe as a flood light. Very happy with it.
So, anyway, yesterday I removed the old light/lens housing from the arm and the bracket for the light virtually bolted straight on. However the led light didn't weigh enough so the arm wouldn't stay down. So I used a spring balance to measure how much extra weight I needed. Came out at around 600g.
Then I started looking at what I had to use as a weight. As it happened the two old bearings from the front pulley of my mill weighed in at around 600g. So I made a bracket t hold them onto the light head. Worked out really well. Just cable tied them to the bracket.
Also knocked up a rough bracket to enable the light arm to be clamped to the mill table.
Throws a lot of light- It might turn out to be a bit big for the machine though. Will wait till I use it for real.
Peter
11th Jan 2021, 01:06 PM #2460Golden Member
- Jan 2016
- Wodonga Vic
- 38
- 633
Springs fitted, not exactly the springs I was after but they'll do until I find something better. maybe someone here has a lead I can follow?
latest little project
