Results 1 to 13 of 13
    Apr 2010
    Croydon
    10
    Default Anyone know company that can extend reamer length?
    Hi all,
    I have 2 machine reamers, 23/64" and 27/64" respectively. Both are 7" overall in length.
    I need a piece of round bar brazed on to extend out to 12".
    Any ideas who or where I can have this done?
    Victoria preferably but I can send country wide.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Are they M/T or Straight Shank.
    Apr 2010
    Croydon
    10
    Straight shank chucking reamers
    Apr 2010
    Croydon
    10
    Similar to this
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Does the reamer when finished need to pass through a hole 12" long at the Diameter stated.
    Apr 2010
    Croydon
    10
    Hi,
    it needs to pass through a 11 5/8" length.
    near Rockhampton
    6,218
    How about a 3/8 drive socket on the square and go from there....
    I have put sockets on taps to extend their length...
    Apr 2010
    Croydon
    10
    The length of the piece is 11 5/8" long. The bore throughout is 23/64. This is a chucking reamer, not a hand reamer so there is no square. I've had them extended before in whilst I lived in the UK by brazing a piece of round bar to the reamer.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Have you got facilities to finish machine the reamer after it is extended.
    Apr 2010
    Croydon
    10
    Unfortunately not. Wood lathe only. I'm thinking probably the most accurate way to do it would be to utilise the small bore in the end of the reamer and turn a male end on sone round bar then braze together. Anyone out there have this capabilty who is willing to take on this small project for a fee?
    Jul 2006
    Athelstone, SA 5076
    4,258
    any smaller type machine shop should be able to do it
    the larger ones can also do it , but would they as it may be too fiddley for them.
    Mar 2009
    54
    825
    Depending on the diamater of the shank and wheather it is hardened or not your best bet would be to reduce the diamater of the last 25mm of shank to say 6mm (7/32") then bore a press fit size hole into some appropriate size stock, inset the reamer then braize to secure.
    This is probably suitable if you plan to use the reamer for a few one off type jobs but if you plan to use it for production runs you might need to source custom made reamers.
    If you decide to have a go at extending them, PM me and I can probably have a crack at it for you.
    I'm assuming you are in Croydon Vic?
    Greg.
    Jun 2008
    Lindenow
    50
    869
    Quote Originally Posted by kwijibo99 View Post
    Greg.
    This would be the best option in my opinion..
    I would take Greg up on the offer. Also if you are lucky Greg will have a tool post grinder and be able to finnish the extention back to a near factory finnish..
    Warning Disclaimer
  1. How do you Use a hand reamer
    By rodm in forum METALWORK GENERAL
    Last Post: 7th Feb 2010, 08:28 PM
  2. Hand reamer problems
    By Threebob in forum METALWORK GENERAL
    Last Post: 15th Nov 2009, 07:10 PM
  3. 1MT Reamer
    By Garell in forum METALWORK GENERAL
    Last Post: 11th May 2006, 11:24 PM
