Results 1 to 12 of 12
Thread: sheraton conquest lathe
6th Jun 2010, 03:41 PM #1New Member
- Jun 2010
- yenda nsw
- 8
i have had an ex army sheraton 600 conquest lathe since 1990,but only recently decided to cut threads with it.when the unit was purchased it was not confirmed that the gear set was complete.from reading the chart it appears most of the gearing is complete and i can cut most imperial and metric threads,however i am running into trouble trying to engage the lead screw with reference to the chasing dial when trying to cut 16 TPI.the only screw gears(dial gears) i have are 24 ,33 and 35 tooth which are mentioned on the metric chart.do i need other thread dial gears to chase imperial threads from the lead screw.any help would be greatly appreciated as i am pulling my hair out at the moment after trying every combination of dial gears i have only ended up cross cutting threads galore.cheers leopardwood
6th Jun 2010, 05:12 PM #2Boilermaker
- Mid North Coast NSW
- 45
- 177
Is the leadscrew metric or imperial?
6th Jun 2010, 05:45 PM #3New Member
- Jun 2010
- yenda nsw
- 8
hi ben the lead screw is 3 mm metric,the lathe according to the plate was delivered to the army in 1977.cheers jb
6th Jun 2010, 06:12 PM #4Boilermaker
- 45
- 177
Ok there's your answer. You won't be able to cut imperial threads using the thread chasing dial. You need to lock the half-nut and then cut the thread by driving the lathe in forward, back the compound out then drive the lathe in reverse to get back to the start of the cut. Then repeat. You'll be able to cut metric threads using the dial though.
6th Jun 2010, 06:21 PM #5Pink 10EE owner
- 6,216
6th Jun 2010, 06:24 PM #6New Member
- Jun 2010
- yenda nsw
- 8
thanks ben for your prompt reply.i have successfully cut imperial threads using the method you described.but i was getting the cutting tool into the chuck or the work far too often,i erroneously thought i could cut imperial threads from a metric lead screw from the dial simply by marking the dial.and engaging the half nuts on the scratch mark.thankyou very much for setting me straight.this lathe does not have a brake on it so i am finding it hard to arrest the progress off the cutting tool at the completion of the run.thaks again jb
6th Jun 2010, 07:18 PM #7
What revs are you running when screw cutting?
6th Jun 2010, 07:54 PM #8New Member
- Jun 2010
- yenda nsw
- 8
60 rpm cheers jb
6th Jun 2010, 08:13 PM #9
Speeds are OK, are you cutting a "ditch" at the end of the threaded length?
6th Jun 2010, 08:31 PM #10Boilermaker
- 45
- 177
If you use very sharp HSS and plenty of coolant, there is no reason why you can't turn the chuck over by hand and get a great finish and perfectly formed threads.
6th Jun 2010, 10:10 PM #11New Member
- Jun 2010
- yenda nsw
- 8
thanks gavin and ben.i have just returned jubilant from the shop and successfully cut the afore mentioned thread.by the method suggested ie leaving half nuts engaged and forward/reverse feeds.i am sure my ealier failures were operator inexperience,i have now learned (painfully) to back of the cross feed simultaneuosly at shutdown to clear the work and also double check the forward reverse switch prior to start.yes i am cutting a trench at the end of the thread and thakyou for your interest and speedy replies.cheers jb
7th Jun 2010, 08:59 PM #12Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,277
My Apprentice Trainer used to say
"If your not making mistakes, you are not doing anything......"
Well done on a successful thread cut.
Sterob
sheraton A steady?
By danielhobby in forum THE HERCUS AREAReplies: 3Last Post: 13th May 2010, 01:49 PM -
Sheraton lathe. Need some pull it apart info...
By _AL_ in forum THE HERCUS AREAReplies: 4Last Post: 3rd Mar 2010, 07:36 PM -
Sheraton lathes from 600
By benskyring in forum METALWORK GENERALReplies: 27Last Post: 14th Nov 2009, 10:42 AM -
Sheraton Lathe
By electrosteam in forum METALWORK GENERALReplies: 4Last Post: 9th Jul 2009, 11:38 AM -
Sheraton Lathe information?
By Greg Q in forum METALWORK GENERALReplies: 18Last Post: 25th Jun 2008, 09:36 PM
