Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 62
  1. #16
    Mar 2009
    54
    825
    Thanks for that Vernon, works a treat
    Very nice bit of work indeed.
    Greg.
  2. #17
    May 2010
    Lower Lakes SA
    58
    2,607
    Sounds very handy. Can't run it on the mac though.
    Was it too complex for a spreadsheet?
  3. #18
    Oct 2006
    Armidale NSW
    52
    915
    Quote Originally Posted by Bryan View Post
    Can't you run it on something like WINE?
    Don't know ... possibly. I don't normally use spread sheets other than for relatively simple calculations.
    Cheers.
    Vernon.
  4. #19
    Jun 2010
    Darwin
    80
    2
    Vernonv,
    As I have just invested in a new Hafco Al-320 lathe and as I have not yet got my brain around the thread cutting bit this sounds like just what I require, however have tried both my Vista and the cheese & XP to no avail
    Regards & keep smiling
    Les.
  5. #20
    Oct 2006
    Armidale NSW
    52
    915
    Just a bit of an update on the download issues ... I can open the file OK if downloaded via Firefox, but I can't if I download via IE.
    Here are a couple of knowledge base articles from MS.
    Issue with XP - Zip Files Downloaded with Internet Explorer Are Not Saved to Your Computer
    Issues with IE and the server - An error occurs after downloading a .ZIP file with Internet Explorer (MS are blaming the server settings not IE ).
    Cheers.
    Vernon.
  6. #21
    Oct 2006
    Armidale NSW
    52
    915
    Default New version v1.0.1
    Hi,
    I've finally gotten around to adding some improvements (I hope ) to the lathe gears calculator. In this version:
    • You can select setups for different lathes. There are only a couple in there at the moment - note that if you know the settings for a particular lathe, let me know what they are and I will add it.
    • The calculation of ratios is much quicker now.
    • There is a "find missing gear" function that allows you to figure out what gear you are missing for a particular thread you are wanting to cut.
    • You can sort the results list by clicking on the column headings.
    Thank you to those who have posted, PM'ed and emailed me suggestions and lathe gear setups. Like I said above if you have a lathe gear setup for a particular lathe, save it under the <Generic> setup and email me the LatheGears.ini file and I will add it to the program ... that way we can share the knowledge.
    Again, feedback and suggestions welcome. BTW mods, feel free to remove the old zip attachments if you wish.
    Cheers.
    Vernon.
  7. #22
    Jul 2007
    On the Bellarine
    167
    Thanks Vernonv..........have forwarded an email with gears, leadscrew and specs for my AL320G.......appreciate your efforts..................Lee
  8. #23
    Sep 2009
    West OZ
    151
    Great work Vernon! Love the upgrades. Cheers
  9. #24
    Jan 2004
    Mackay North Qld
    6,446
    Thank you Vernonv,
    It will be useful
  10. #25
    Oct 2006
    Armidale NSW
    52
    915
    Better late then never. Here is the latest upgrade to LatheGears with lots of changes mostly based on user feedback.
    One of the biggest changes is the ability to set fixed gears i.e. you can set 1, 2, 3 or 4 (unlikely 4) gears that MUST be used in the calculations.
    The zip file contains a installation exe file.
    I'm still looking for additional .lat (lathe) files that people may have set up for particular lathes. This will allow me to add more "standard" lathes to the selection list.
    All feedback welcome ... and I will eventually get around to including it if I can.
    Enjoy.
    Cheers.
    Vernon.
  11. #26
    Jul 2008
    near Warragul, Victoria
    3,726
    Default Great
    thanks so much Vernon
    I downloaded the latest version, but my unzip software doesn't open it . I have XP .............. Mike
    Extracting to "c:\unzipped\LatheGears2\"
    Use Path: yes Overlay Files: no
    warning [C:/download/LatheGears2.zip]: extra 417 bytes at beginning or within Zip file (attempting to process anyway)
    Error in file #1: bad Zip file offset (Error local header signature not found): 0
    (attempting to re-compensate)
  12. #27
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Mike,
    If you want to, pm me your email and I'll send it to you unzipped.
    Ewan
  13. #28
    Jul 2008
    3,726
    Default problems
    Mike,
    Ewan
    Ewan
    That exe file didn't work, I think some of it is missing . Don't worry.
    I've tried 3 different unzip programmes, but I cannot unzip Vernons zip files with any of them .
    I will try it on another computer ..maybe the library if I ask them nicely
  14. #29
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Ewan
    Mike,
    It installed for me, but now it is saying ACE32.DLL is missing.
    A little help please Vernon?
    Ewan
  15. #30
    Oct 2006
    Armidale NSW
    52
    915
    Not sure why the unzip isn't working???? I will look into the ACE32.DLL issue tomorrow and upload a fix.
    Cheers.
    Vernon.
  1. Hercus Change Gear Diameter
    By pipeclay in forum THE HERCUS AREA
    Last Post: 15th Jun 2009, 01:41 AM
  2. Restoring Hercus Gear Change Plate
    By wannabe in forum THE HERCUS AREA
    Last Post: 19th Nov 2008, 04:26 PM
  3. Hercus Change Gear Guard
    Last Post: 2nd Sep 2008, 03:36 PM
  4. Hercus Gear Change Plate
    By John Richards in forum METALWORK GENERAL
    Last Post: 16th Feb 2007, 01:24 AM
  5. Sheraton gear change chart?
    By warlock in forum METALWORK GENERAL
    Last Post: 29th Jun 2005, 02:49 PM
