Results 1 to 3 of 3
Thread: Taper turning with the top slide
20th Jan 2010, 08:52 PM #1Pink 10EE owner
- 6,218
I came across a description on setting the top slide for taper turning and so far it is the easiest method I have come across..
You need a dial indicator with magnetic base and an accurate method to measure the movement of the saddle along the bed...I use the DRO..
It works like this.. You work out the taper you need in mm/m or inches/ft or whatever measurement you want to work with...
You then put the magnetic base on the bed and put the dial indicator against the top slide... Now you put the top slide to the approximate angle you require.. You zero the dial indicator and move the saddle along the bed a certain distance, taking note of the amount the dial indicator moves.. From this you can work out the taper the top slide is set at and move it accordingly.. It is a lot easier to do then explain... Here are some pics..
22nd Jan 2010, 10:22 AM #2spit
- Jan 2010
- Isle of Man
- 74
- 7
That's a beaut RC, should stop the taper from forever walking towards the headstock..
23rd Jan 2010, 02:36 PM #3Golden Member
- Apr 2008
- NSW
- 537
That way is a good idea if you have DRO .
This is my solution if you don't have a DRO. http://www.woodworkforums.com/f189/m...r-gauge-80354/The volume of a pizza of thickness 'a' and radius 'z' is given by pi z z a.
Bernie O'Dea Taper Turning Attachment
By kwijibo99 in forum THE HERCUS AREAReplies: 2Last Post: 21st Oct 2009, 09:15 PM -
Looking for a Taper turning attachment
By aljunk in forum THE HERCUS AREAReplies: 10Last Post: 27th Dec 2008, 11:47 PM -
Make a top slide short taper gauge
By Retromilling in forum THE HERCUS AREAReplies: 2Last Post: 8th Oct 2008, 09:42 AM -
Make a top slide short taper gauge.
By Retromilling in forum METALWORK GENERALReplies: 0Last Post: 7th Oct 2008, 09:47 AM -
Morse Taper Turning
By jvdv in forum METALWORK GENERALReplies: 46Last Post: 13th Sep 2006, 03:26 PM
