Results 1 to 15 of 20
Thread: How to fix cast metal
6th Jan 2010, 05:25 PM #1The Apprentice
- Oct 2009
- Wantirna Sth. Melbourne
- 27
G'day Guys,
I need some help in finding out on how to fix bandsaw housing which is made out of cast metal. The problem started when I was sawing wood and noticed the machine wobbling, further investigations revealed a crack where the base is mounted to the body and I'm just wondering, before I lay down and cry, if one of you guys had any experience in fixing such a problem?
Jack
6th Jan 2010, 05:43 PM #2
It could probably be welded with care, I've welded cast iron in the past, but it depends on how good the metal is. Welding cast is not 100% guaranteed even with good quality base metal to work with.
From the photos it looks like the broken piece is angled at pretty close to 90 degrees, if it were my machine, rather than welding it, I'd consider making up a piece to replace the broken part out of plate, say 3/16" to 1/4" that could be bolted in a number of places to the remaining part of the machine with load spreading washers on the inside of the saw housing.
Or maybe some plates drilled through the main part of the saw and the broken part to hold the broken bit back in location, maybe with some JBWeld http://www.lprtoolmakers.com/special...eld/JBweld.htm to assist.
Good luck
6th Jan 2010, 05:47 PM #3Pink 10EE owner
- 6,218
Your choices are weld it with cast iron/nickel rods.
Or braze it...
I would probably braze it then reinforce it with some strips of steel..
6th Jan 2010, 06:04 PM #4
I think it is a small GMC bandsaw,and is probably Diecast alloy of some sort.They used a cast iron base to stop them falling over but alloy for the vertical back of the bandsaw.Not a good idea.Try a magnet on the broken bit Jack.If it doesnt cling to it it is diecast alloy and maybe a different!!!! means of repair.
Very sorry if I am wrongBack To Car Building & All The Sawdust.
6th Jan 2010, 06:20 PM #5Member
- Nov 2009
- australia
Judging by the photos, it sure aint cast iron, too shiny for cast iron, possibly cast alloy of some sort, you better device some way of holding it all together with a plate and bolts.
Go near it with any source of good heat and you'll find it turning into a puddle.
Mark
6th Jan 2010, 08:48 PM #6
Hi Jack.
First of all ,is it cast iron or is it cast aluminium? Neither metals are easy to weld by an inexperienced welder.
If a magnet sticks to it, it is likely that it is cast iron.
If it is cast iron it can be welded.I used to weld cast iron with oxy acetylene,so I know it can be welded sucessfully,but it takes knowledge and the skill to weld it.
To me, it appears to be cast aluminium which wont lend itself to repair by a DIY person.
It is best left to an aluminium welding specialist company.
Can you get a spare part? If not I suppose you have to balance the repair quote against that of a new machine or as has been suggested, mechanically join the broken parts or possibly use them as a template to make a copy out of steel.
6th Jan 2010, 08:51 PM #7The Apprentice
- Oct 2009
- 27
It's cast aluminium or similar alloy not to sure, no magnet sticks.
Jack
6th Jan 2010, 09:03 PM #8
It look mighty close to this model.GMC http://www.gmcompany.com/download/pr...30L_IM_ed5.pdf
page 7 gives a look at the RHlower corner I think Ryobi sold them as well
I remember a thread a week or so about this saw
PS when you blow page upto 400% it looks like there is a steel suport bracket under the two bolts.Was that in yours Jack?Back To Car Building & All The Sawdust.
6th Jan 2010, 10:07 PM #9The Apprentice
- Oct 2009
- 27
6th Jan 2010, 10:18 PM #10
Devcon is your friend......
Collins Industrial Distributors: Concrete Repair -> Devcon - Metal Repair -> Metal-Filled Epoxy
The last product on this page is Devcon Fasmetal - a high strength aluminium-filled epoxy. I've used it to repair damaged aluminium parts; it is VERY strong, and hard enough to allow machining of the completed repair.
This stuff was actually developed as an alternative to welding or brazing.
6th Jan 2010, 10:36 PM #11The Apprentice
- Oct 2009
- 27
6th Jan 2010, 10:54 PM #12
Its widely used - a couple of metalworking/machining places in our area keep both the aluminum and steel versions of Devcon. Very useful for fixing silly mistakes....
I've always been able to scrounge the small quantities I needed without ever buying a tub.
If you want to go the cheap route, use slow-curing (24 hour) Araldite, with accelerated cure using a heat gun. Reduces viscosity, keys into the surfaces better, sets hard as glass. Alternatively, go ahead and try brazing it.............
7th Jan 2010, 08:00 AM #13The Apprentice
- Oct 2009
- 27
8th Jan 2010, 03:27 PM #14The Apprentice
- Oct 2009
- 27
G'day All,
I wondered into Autobarn and bought myself J-B weld, it cost me $20.00, and it is as good as they claim. In less than 4hrs it was rock hard I left it to cure overnight and its BLOODY good. I've added a couple of brackets for extra strength and beefed it up slightly I also added extra plates between the body and the mouting base.
Thanks everyone for your input and advice.
Best Regards
Jack
8th Jan 2010, 03:45 PM #15
Good one Jack.
Can you put a photo up please?Back To Car Building & All The Sawdust.
How do I weld Cast???
By g_man in forum WELDINGReplies: 27Last Post: 4th May 2009, 01:17 PM
