Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    Nov 2009
    Australia
    12
    Even if everything was coming off the same power supply, the light would add an extra 100W maximum and the coolant pump would likely be not more than 250W. This means the total power consumption with everything going is 1850W which would draw 7.7A on a 240V circuit. It should still be no problem. Hope this helps some..
    Jay
  2. #17
    Sep 2009
    Sydney
    45
    18
    The lathe has a 12v work light and a 1/8 hp coolant pump.
  1. requirements for a 15a circuit
    By 19brendan81 in forum WELDING
    Last Post: 6th Jun 2009, 11:36 PM
