Results 1 to 2 of 2
16th Sep 2009, 08:08 AM #1
New place that sells Aluminium at Geebung on northside of Brisbane...
Dear Gents,
When "Smart Aluminium" was taken over by "Capral" a couple of years ago, their outlet at Geebung (where you could buy extruded-Aluminium sections by the metre, rather than by the whole 6m-stick...) was quietly closed down. After that, unless you went for a drive up to Brendale (where I presume there might be someone that sells Al by the metre...), you were faced with the option of buying what was available at the nearest BigB in either ridiculously expensive 1m-lengths, or in more reasonably priced 3m-pieces (that only just fitted into the car, and were still dear anyway if you only needed about 1.2m worth...)
Well - fret no more, because there's a new place in Geebung that only opened about a month or so ago, and they sell the stuff by the metre at realistic prices...
Their name is: "Action Aluminium"
Their address is: Unit 13/210 Robinson Rd, Geebung (it is on the southside of Robbo Rd, in a brand-new drive-in Industrial Mini-Park setup that is not very far to the West of "Glenfords"...)
Their phone no. is: (07) 3265 7150
To give you an idea of how their prices stack up, consider that a 1m piece of 25 x 12 x 1.6 UA will currently set you back $4.39 at the BigB. The same length of the same section at "Action" will cost you all of $2.00 (incl. GST). Enough said...
Since it also now has a Steel-by-the-metre place on Newman Rd, Geebung Rocks - no doubt about it...
Best Wishes,
Batpig.
19th Sep 2009, 10:10 PM #2
"Geebung Rocks - no doubt about it...""
Shush!!! They will all want to live there!!!!
sourcing - aluminium MIG wire - Brisbane
By Mindabout in forum WELDINGReplies: 3Last Post: 16th Aug 2008, 09:49 AM -
Pressed aluminium sheeting in Brisbane
By dan_tom in forum METALWORK GENERALReplies: 6Last Post: 22nd Aug 2005, 04:32 PM
