Results 1 to 3 of 3
    Aug 2004
    Brisbane
    184
    Default font size in Neil's skin
    Can someone tell me what the font size is in Neil's skin? I pasted some text into a reply window which changed the font and when I set it back to verdana, size 2 was too small and size 3 too big??
    Jun 2006
    Vic
    5,631
    The font sizes should be the same across all skins as the WYSIWYG editor is used on all skins.
    I'd say the problem more than likely will be with the text you were pasting in.
    Try pasting it and then click on the up in the upper right corner and see what other code has been pasted in with the text. In 99% of the editing I do with problem postings here on the forum, there is code hidden amongst the text and by using the Editor mode, I can remove the problem coding.
    DJ
    ​ADMIN
    Aug 2004
    Brisbane
    184
    Ta DJ, I'll give that a go.
