Results 1 to 9 of 9
Thread: Forum problems
30th Apr 2008, 10:49 PM #1New Member
- Apr 2008
- QLD
- 6
Forum problems
Hi,
Im having heaps of problems starting new threads in the concrete section, it keep asking me for a password etc even though im already logged in. I re log in but still asks for password.
Also on a thread i did manage to start the posts disappear & always need to refresh the page to see new recent posts.
Is it my browser or something ? (IE 7)
Any one know why ?
Thanks.
30th Apr 2008, 11:02 PM #2
Jake are you referring to this thread? Or are you trying to start another new thread?
As for the logging in, can you check to see which url you were logging in on, if you logged in on one but but sometimes you may follow a link and you might be switching to another url where you may need to log in again. For example you have woodworkforums.com and woodworkforums.ubeaut.com.au.Cheers
DJ
ADMIN
30th Apr 2008, 11:43 PM #3New Member
- Apr 2008
- QLD
- 6
Didn't realise there was two forum names.
Tried the one on your post & i could see my post but couldn't start a new thread as it won't let me in.
Even on this thread i had to refresh the page just to see this post. (edit)
Why the two different web names anyway ?
1st May 2008, 12:33 AM #4
Because we started with woodworkforums.ubeaut.com.au in 1999 and changed to the more direct woodworkforums.com which is easier for some search engines to find and keep records of because a lot of record keeping sites don't recognise the .com.au tag To confuse things even more we later added woodworkforums.com.au to keep others from using the name.
Log into either one then click the remember me box if that doesn't work log into woodworkforums.ubeaut.com.au and woodworkforums.com, do the remember me thing and DON'T log out when you finish. This will let you back in without a need to log in each time.
Every time you log out you clear all the cookies from your computer and will need to log in from scratch. If you don't log out your session will end when you leave the forums or close down the site but you will not delete cookies and will be automatically logged back in when you return.
Cheers - NeilAre you a registered member? Why not? CLICK HERE TO REGISTER. It's free and takes less than a minute!
1st May 2008, 03:33 AM #5
"Remember me" has usually worked for me to link the separate domains. And automatic login has also been my experience. But it seems that when I do take such a break (usually because I can't log out due to apparent database backup), my new login resets the "You last visited" field, and New Posts are relative to the new login - a bit awkward if I've been away for a few days and "Today's Posts" leaves a gap. Short of manual intervention by a moderator, is there any way to recover the previous "you last visited" date/time? Or some nearby value? Shouldn't be in my cookies if they've been cleared as stated.
JoeOf course truth is stranger than fiction.
Fiction has to make sense. - Mark Twain
1st May 2008, 05:28 AM #6
1st May 2008, 06:23 PM #7New Member
- Apr 2008
- QLD
- 6
Thanks for the replies, i use a couple of other forums & have no problems so not sure whats going on.......will have another go soon.
Cheers.
1st May 2008, 09:41 PM #8New Member
- Apr 2008
- QLD
- 6
How annoying.
This is the message i keep getting below.
For some reason i can start a new thread on the subjects either above or below the concreting one no problems but not this one.
Im already logged in so i shouldn't be asked to log in to start a new thread.
I really don't understand whats going on.
MessageYou are not logged in or you do not have permission to access this page. This could be due to one of several reasons:
- <LI class=smallfont>You are not logged in. Fill in the form at the bottom of this page and try again. <LI class=smallfont>You may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
- If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
1st May 2008, 10:49 PM #9New Member
- Apr 2008
- QLD
- 6
Finally !
A refresh done when the message appears & then im logged in & can post, don't know why but it worked.
Forum Login Problems
By Gumby in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 53Last Post: 10th May 2007, 12:12 AM -
Forum Problems
By DavidW in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 2Last Post: 27th Aug 2003, 10:30 AM
