Results 1 to 5 of 5
Thread: Forum Bug (Kind of)
13th Nov 2007, 01:49 AM #1Novice
- Nov 2006
- Tweed Coast, NSW
- 19
Forum Bug (Kind of)
Have noticed when you click on sub-header for a collapsed forum section, you lose settings, login, skin etc.
Is it just me?
Using IE6 (IE7 Sucks)
A suggestion/irk also, any way of removing sub-headings when forum section is expanded, seems a bit of double redundancy to have sub-headers and sub-forums showing at same time..
13th Nov 2007, 02:29 AM #2
No problem here Cruzi.
Reported.woody U.K.
"Common looking people are the best in the world: that is the reason the Lord makes so many of them." ~ Abraham Lincoln
13th Nov 2007, 03:15 AM #3
OK here also.
What am I running.....late for Bed.
'Poota igganant I amNavvi
13th Nov 2007, 09:01 AM #4
Most forums are set to Default which is wiki-blog skin (light and dark dray) If you are using another skin it is possible that some may change when clicked on. A few forums have their own colours notably the Drivel forum and Open Slather.
If you are losing log in etc try logging in through www.woodworkforums.com instead of www.woodworkforums.ubeaut.com.au or log in to both. Unfortunately we need to have both as the latter was our original and has been listed since day one in search engines woodworkforums.com is only a few years old and although it is now the default address we aren't able to separate the 2 or there would be dead links in search engines, archives, links from other sites etc.
You can also log in via woodworkforums.com.au not that it will make any difference to what happens.
13th Nov 2007, 10:40 AM #5Novice
- Nov 2006
- Tweed Coast, NSW
- 19
Ok thanks, will try that
