Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Jan 2016
    Wodonga Vic
    38
    633
    Default Woodwork Forum Account Issue
    G'day
    A long time ago I made an account over at the woodwork forum but my account never worked properly, I can't post or even access my own account profile details, I just keep getting an error message which I've screenshot and attached below.
    I messaged one of the mods or administrators recently but haven't heard back.
    I've got some woodwork projects coming up and it would be great if I could participate in the forum.
    Can anyone here help?
    Ben
    7,189
    I had a look in the members list and can't see you there. I don't know what else to do from here but hopefully Grahame will be along soon and can look into your situation.
    Feb 2009
    moonbi nsw Aus
    69
    364
    I have a regular "user" since 2009. My computer opens up with my Mail account Woodwork Forum and Metalwork Forum every day. I have not been able to access the Woodwork Forum for more than a month now, I only get Error 403.
    My daughter is a Computer Tech for a living and she has run all sorts of tests and scans etc etc and her diagnosis is that the Woodwork Forum will not recognize my Account. She has also thinks there is a problem with our satellite provider (We are getting our Internet via satellite dish because of our rural address)
    Its very frustrating as I miss the Forum
    Just do it!
    Kind regards Rod
    Jan 2014
    Sydney North Shore
    11
    Wondered why I hadn’t seen recent posts from you. Do you want me to drop a “help” in the Woodwork Forum” for you?
    Feb 2009
    moonbi nsw Aus
    69
    364
    Yeh thanks that would be a start
    Just do it!
    Kind regards Rod
    Aug 2009
    East Warburton, Vic
    357
    I’ve looked you up over at WWF, you’re showing as “Users awaiting email confirmation”
    DJ
    Aug 2009
    East Warburton, Vic
    357
    Quote Originally Posted by chambezio View Post
    Have you tried clearing your cache/cookies?
    DJ
    Jan 2014
    Sydney North Shore
    11
    I posted on the WWF and will paste replies I receive here.
    From Poundy
    ok, so I can't help directly, but here are the things I would do.
    Incognito/ in-private browse to https://www.woodworkforums.com/ and no other URL. See if that works at all, or generates the 403 still; if not, then your IP is for some reason being blocked by the forum. The reason the MWF is different, is because it's a different instance of the forum software (even though it resolves to the same server IP address) and therefore may have separate IP block lists. If that works, but doing the same not in the in-private/incognito window I'd clear cookies related to the forum.”
    Jan 2014
    Sydney North Shore
    11
    WWF shows your last activity was at 11:41am today so I assume you are back on?
    Aug 2009
    East Warburton, Vic
    357
    Quote Originally Posted by NedsHead View Post
    G'day
    Ben
    Ben, I have been informed via Neil (uBeaut) that he has changed your user status from awaiting email confirmation to Registered, so you should be good to go
    DJ
    Aug 2009
    East Warburton, Vic
    357
    Neil (uBeaut) has sent previous message (21st June) regarding this and has sent you an email today via MWF.
    DJ
    Jan 2014
    Sydney North Shore
    11
    Chambezio.
    Neil sent this message to me to post to you.
    Can you please tell Chambezio to check his PM's on MWF. I sent a message that should sort him out. Could you also ask him to please respond after trying to log in to WWF again so I can follow up if needed.
    Sent 2 PMs to him on WWF whilst he could still log in also an email none were responded to. Email may not have been received but PMs were definitely delivered and not read any time during the preceding 6 days that he was online”
    Jan 2004
    Mackay North Qld
    6,446
    I have notified Admin of the problem.
    Jan 2014
    Sydney North Shore
    11
    The message above is what Ubeat asked me to post so they are aware of the problem. Just waiting for Chambezio to reply to Neils requests.
  15. #15
    May 1999
    Grovedale (Geelong) Victoria
    74
    6,489
    Both problems were solved today.
    Nedshead....
    Your problem was because you didn't respond to the conformation email sent to you when you registered. This could be because the email was blocked by your server or email settings as it is an auto generated message. That was fixed early thisarvo (Tuesday).
    chambezio.... Your problem was quite a bit more of a problem but had to do with you IP address hitting the forums 110,000+ in a 20 day period along with another 2 others that created 141,000 hits.
    PMs were sent to you on 21st June and an email was also sent. I had no response to any and when an automated filter was put on around 29th June it would appear your IP was deleted. Details which
    would have kept you online and what was needed were in the PMs and email. But obviously you didn't see them or ignored them.
    The PM sent to this forum for you today should explain and if you read the ones on WWF you should get the full picture.
    Your IP wasn't deleted by admin it was most likely done by the auto program.
    Hope this is of help to you both.
    Cheers - Neil
    PS: For future reference. Anyone with a problem on here or WWF who can't post for some reason please use the Contact US link at the bottom of all pages and you should get fast help. May not be instant but should be well within 24 hours. The Contact Us​ link works even if you're not logged in.
    Are you a registered member? Why not? CLICK HERE TO REGISTER. It's free and takes less than a minute!
  1. Deleting account
    By G Force in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 20th Sep 2019, 10:33 PM
  2. Trouble typing on woodwork forum
    By wireliner in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 3rd Jul 2014, 08:03 AM
  3. Hi! Help with setting up account
    By tfscott in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 22nd Aug 2013, 09:04 PM
  4. Sub forum issue with limited number of threads, maybe?
    By Canoath in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 4th Oct 2012, 11:51 AM
  5. Hey where did the woodwork pics forum go?
    By mic-d in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 24th Aug 2008, 10:25 AM
