Results 151 to 165 of 211
Thread: Squirrels on strike???
6th May 2015, 03:42 PM #151
Steven looking into it.
However for anyone who is still having a problem please try doing traceroute for the forums from the command prompt using the below command:
tracert woodworkforums.com
This will show if there are any dropped routes along the path to the destination server.
Click here for info on using traceroute if you're not sure how it works.
If you find any dropouts please copy and past the full result from the traceroute into this thread.
Hope this helps.
Cheers - NeilAre you a registered member? Why not? CLICK HERE TO REGISTER. It's free and takes less than a minute!
6th May 2015, 05:12 PM #152Intermediate Member
- Jun 2003
- Brisbane, Qld
- 33
Sure - I can't even ping the server. Traceroute from an optus cable connection (122.108.189.x) which can't connect:
ceres danny$ traceroute www.woodworkforums.com
traceroute to www.woodworkforums.com (209.95.48.51), 64 hops max, 52 byte packets
1 192.168.198.254 (192.168.198.254) 0.895 ms 0.619 ms 0.599 ms
2 10.66.0.1 (10.66.0.1) 11.280 ms 10.846 ms 19.984 ms
3 rdl1-ge1-2.gw.optusnet.com.au (198.142.160.201) 10.820 ms 10.632 ms 10.967 ms
4 * * *
5 * * *
6 198.142.250.221 (198.142.250.221) 23.738 ms
198.142.250.229 (198.142.250.229) 22.087 ms *
7 * 198.142.139.116 (198.142.139.116) 21.192 ms 32.246 ms
8 198.142.139.132 (198.142.139.132) 25.524 ms 36.858 ms 24.782 ms
9 203.208.192.205 (203.208.192.205) 178.758 ms
198.142.139.116 (198.142.139.116) 36.220 ms 27.035 ms
10 203.208.171.118 (203.208.171.118) 169.393 ms
203.208.158.122 (203.208.158.122) 199.109 ms
198.142.139.132 (198.142.139.132) 37.522 ms
11 203.208.174.189 (203.208.174.189) 182.592 ms
203.208.192.205 (203.208.192.205) 182.485 ms 181.483 ms
12 ae0.cr2.lax112.us.zip.zayo.com (64.125.32.78) 178.079 ms 177.298 ms
203.208.172.146 (203.208.172.146) 181.754 ms
13 203.208.151.101 (203.208.151.101) 179.402 ms
ae12.mpr1.slc1.us.zip.zayo.com (64.125.21.222) 193.179 ms 203.188 ms
14 208.184.34.150.ipyx-068416-003-zyo.above.net (208.184.34.150) 208.697 ms 195.821 ms 201.707 ms
15 206.130.126.30.west-datacenter.net (206.130.126.30) 191.951 ms
ae12.mpr1.slc1.us.zip.zayo.com (64.125.21.222) 200.840 ms 202.458 ms
16 * * *
17 * 206.130.126.26.west-datacenter.net (206.130.126.26) 196.258 ms
206.130.126.30.west-datacenter.net (206.130.126.30) 211.842 ms
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 *^C
6th May 2015, 06:12 PM #153
6th May 2015, 06:15 PM #154Intermediate Member
- Jun 2003
- Brisbane, Qld
- 33
Me too - I am connected again from the connection that wasn't working before - thanks team!
6th May 2015, 09:30 PM #155
6th May 2015, 09:33 PM #156
7th May 2015, 12:28 AM #157
Now it works for me without using TOR. Nonetheless here is the routing with TOR on and then with TOR off.
TOR routing
Tracing route to woodworkforums.com [209.95.48.51]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 192.168.1.254
2 24 ms 24 ms 23 ms 172-9-4-2.lightspeed.snantx.sbcglobal.net [172.9
.4.2]
3 24 ms 24 ms 24 ms 75.28.192.122
4 28 ms 28 ms 28 ms 12.83.39.17
5 34 ms 35 ms 31 ms ggr3.dlstx.ip.att.net [12.122.138.17]
6 * * * Request timed out.
7 53 ms 52 ms 87 ms ae7.cr2.dfw2.us.zip.zayo.com [64.125.20.233]
8 68 ms 68 ms 69 ms ae6.mpr2.den1.us.zip.zayo.com [64.125.31.58]
9 68 ms 68 ms 68 ms ae10.mpr1.slc1.us.zip.zayo.com [64.125.21.65]
10 76 ms 75 ms 76 ms 208.184.34.150.IPYX-068416-003-ZYO.above.net [20
8.184.34.150]
11 75 ms 75 ms 76 ms 206.130.126.26.west-datacenter.net [206.130.126.
26]
12 76 ms 76 ms 76 ms 209.95.48.51.static.midphase.com [209.95.48.51]
Trace complete.
Firefox routing
.4.2]
8.184.34.150]
26]The stone age didn't end because the cavemen ran out of stones...
7th May 2015, 12:59 AM #158
My regular access is blocked again. Here's the trace.
.4.2]
8.184.34.150]
26]
Timeouts from this point to #30The stone age didn't end because the cavemen ran out of stones...
7th May 2015, 11:45 AM #159New Member
- 1
If you are on a PC, you could try flushing your DNS by using: ipconfig /flushdns on the cmd line.
For other OSs see here: https://www.whatsmydns.net/flush-dns.html
7th May 2015, 12:15 PM #160
7th May 2015, 01:58 PM #161
I guess the longer time limit also prevents PM's being sent and received to buyers and sellers in quick time.
7th May 2015, 03:10 PM #162Chris
Life isn't always fair
....................but it's better than the alternative.
7th May 2015, 04:10 PM #163New Member
- 1
Agreed, more likely an issue with your DNS provider.
Have your tried updating your DNS settings to different provider.
You could try the Google settings mentioned previously by Evanism.
7th May 2015, 05:39 PM #164
Also make sure you don't have an entry for woodworkforums.com in your computers hosts file.
PS - we're working through a few fixes along with looking into this.Steve
Woodwork Forums
Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds!
8th May 2015, 08:17 AM #165
