Results 1 to 6 of 6
    Jun 2012
    Adelaide
    3
    Default Can,t understand the Auction thingy whatsit
    Hi Guys
    I put up for sale my router table and had to remove it ,simply because I can,t follow simple instructions.
    my item went up for Auction which I did not want, and, I could not make any edit changes to make a simple "For Sale"
    The item is still in the listing under SA Router Table Cast Iron 017
    Guys is there a simple and easy way this dumb soth aussie can put my table up for a simple "For Sale"
    "Help Help Help
    Kind Regards
    Huey
    May 2007
    Burleigh Heads
    69
    81
    The simple answer seems to be just explain it in the body of your listing that it is not an auction and the price is whatever or open to negotiation.
    Aug 2004
    Sunbury, Victoria, Au.
    49
    Quote Originally Posted by Heuy View Post
    Hi Guys
    "Help Help Help
    Kind Regards
    Huey
    It's not only you Huey! I know of a few forum members who have mentioned that they will not use it as well and have gone to Gumtree!
    Russell (aka Mulgabill)
    "It is as it is"
    Dec 2013
    Armidale NSW
    11
    Hi Guys
    "Help Help Help
    Kind Regards
    Huey
    I have seen items in flea bay that are classified ads, I have not used this method personally but I gather it lets you set a fixed price for your item. There is also a facility to add " make an offer" to your advert. potential buyers will make an offer that is sent to you and you can accept it or reject it.
    Re trying to edit your current advert, I don't think you can, I recently tried to do that and was rejected at every turn.
    Nov 2007
    Sydney
    1,107
    The Market Place/Auctions part of the forum is a way of putting up your item for sale. It defaults to Auction and will run for 2 weeks. If the item is not for Auction you can state that in the description. It can also be closed early if the item has been sold. There is more flexibility in this format and all discussions are between the parties involved.
    Jul 2003
    Riverhills, Brisbane
    63
    0
    As well as putting the price in the body of post..you can also put the reserve price & starting bid as the same as the price you want for it then minimum bid as $0
