Results 1 to 2 of 2
Thread: Editing Auction?
6th Oct 2013, 08:26 PM #1New Member
- Jun 2008
- Adelaide, Australia
- 39
- 0
Editing Auction?
Is there a way to edit your auction listing?
I accidentally put a wrong value in the bidding (amount) section and need to change it ?
7th Oct 2013, 01:45 AM #2
G'day Blazk - Editing of any posts on the forums is limited to 12 hrs only.
If you want something changed after that time you need to contact an Administrator or moderator and ask for it to be done for you. Unfortunately we are unable to get the report post action to work properly on the new Market Place so if you report the post you may have to wait a little longer to get it changed as the reports only come up ad emails and not in the Administration section as they should.
There is some minor editing that can be done by sellers and the links to this can be found on the top line above your advert.
We are working on a fix for these problems but not too sure if they can be easily done.
Hope this is some help to you.
Cheers - Neil
PS worst comes to the worst send me a PM of the changes you want and I'll fix it for you.
Editing a messge
By jow104 in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 2Last Post: 27th Jul 2008, 08:08 PM -
Editing your posts
By Ausworkshop in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 5Last Post: 15th Sep 2007, 02:36 PM
