Results 1 to 15 of 19
Thread: Photos not uploading
27th May 2013, 05:25 PM #1
I've been trying today to upload pics to two of my threads and keep getting a 'This is not a valid image file' message.
The threads are http://www.woodworkforums.com/f10/wh...ir-pin-171626/ and Another Cigar Box Guitar WIP - Page 8
I can't add my 'finished' pics to the threads. The pics are the same resolution as I usually upload, and even making them extra-small doesn't help.
Can anyone shed any light on this? Is there maybe a limit on the number of pics a member can upload, or is something else amiss?
I just tried uploading a small pic to this thread with the same result, so it's not merely the threads.
It's not picture size, either, I just tried a little 64KB jpg file and it won't upload.
I just tried and can upload a text file, but jpg, bmp and even gif won't work.
Edit: In 'Settings', it says ' You are currently using 93.75 MB to store 766 uploaded attachments.' It says nothing about having reached a limit or anything like that.... Steve
-- Monkey see, monkey do --
27th May 2013, 06:21 PM #2
For a test, _fly_ just tried uploading a pic to one of my threads and struck the same problem, so it's not just me.
... Steve
27th May 2013, 06:33 PM #3
Hi ,
I have just tried to post a photo to this post and got a ! in a red dot telling me not a "valid image file" it,s a jpg like all the others I have ever uploaded.
RegardsHugh
Enough is enough, more than enough is too much.
27th May 2013, 06:38 PM #4
There is the other post that says lower case extension works and only uppercase doesn't, NOT TRUE.
Made no difference.
should I try jpeg and gif to see if that makes a difference?
Peter
27th May 2013, 06:40 PM #5
OK, just came in from the shed and saw all these posts about picture uploading problems.
So, tried it myself and guess what?
You're right something appears broken coz I got the same error!
B*gger, will report it to the backroom boys and see what they can do.
27th May 2013, 06:44 PM #6
Ok just tried a BMP, GIF, JPEG and PNG, All failed to load as valid images. This is on top of the jpg that people are having trouble with.
Peter
27th May 2013, 06:51 PM #7
27th May 2013, 07:17 PM #8
Uploaded from Photobucket using the IMG link
From Picasa web albums, using IMG link
27th May 2013, 07:43 PM #9
28th May 2013, 12:35 AM #10
Problem appears to be with some errant coding in the uploader. Have put in a request to the Guru but it probably won't be fixed until tomorrow some time.
Prefer that pics were loaded from your computer and stored on the forums rather than stored on an outside source such as PhotoBucket as these often get deleted and ruin threads especially if it is for a WIP or similar.
Cheers - Neil
28th May 2013, 12:43 AM #11
Thanks, Neil, and I agree regarding storing pics on the forums rather than elsewhere. I've seen some good WIPs ruined because the pics had disappeared.
Once this is sorted out, I'll change my 2 threads - delete the PhotoBucket links and upload the pics here on the forums.... Steve
28th May 2013, 02:47 AM #12New Member
- Apr 2013
- Florida
- 73
- 1
Nice to know I'm not alone....could not believe that some limit could be reached so quickly....one could never do an entire build log had that been the case.
Anxiously awaiting the fix......can't build without a build log....
Jim
28th May 2013, 12:14 PM #13
It looks like an automatic software update didn't run properly, uploading images should be fine now
Woodwork Forums
Are you a registered member? Why not? click here to register. It's free and only takes 37 seconds!
28th May 2013, 01:47 PM #14
28th May 2013, 01:54 PM #15
004.JPGAba daba doo it's fixed.
Good work on the fix. This is our favourite toy on this forum.
RegardsHugh
Uploading photos as attachments
By Big Shed in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 1Last Post: 5th Feb 2018, 10:20 AM -
Uploading photos
By BUNDYMARK in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 2Last Post: 8th Mar 2011, 07:23 PM
