Results 1 to 14 of 14
16th Jan 2013, 08:51 AM #1Member
- Sep 2012
- Oz
- 51
Bandsawn Boxes forum shows only threads from last month by default.
I've noticed that when visiting the Bandsawn Boxes forum, it always only shows threads from the last month, instead of from the beginning.
On each visit, I select 'Beginning' from the drop down list, then hit 'Show Threads' and all is fine, but next visit the forum has reverted to only posts from the last month again.
Not real critical, but is this fixable?
Tested with both IE8 and Firefox 17.0.1
OS is XP SP3
16th Jan 2013, 09:07 AM #2
If you're logging off the forum or clearing your cache/cookies between visits then yes it will revert to month by default.
If you're using your own computer at home, there is really no need to log off or clear cache/cookiesCheers
DJ
ADMIN
16th Jan 2013, 09:11 AM #3Member
- Sep 2012
- Oz
- 51
16th Jan 2013, 09:17 AM #4
Settle, I said "if".
In the meantime, admin have been asked if the default can be changed.Cheers
DJ
ADMIN
16th Jan 2013, 11:47 AM #5Senior Member
- Jun 2003
- 326
16th Jan 2013, 11:56 AM #6Member
- Sep 2012
- Oz
- 51
Odd.
Every other forum displays as normal, just not the BS Box one.
I'll clear my WWF cookies, let them get re-created and see what happens. Doesn't bother me, but I thought if it was the same for everyone that visitors might not even realise there were more than 2 threads in the forum.
16th Jan 2013, 12:10 PM #7Member
- Sep 2012
- Oz
- 51
Looks like it's the default for that particular forum at the moment.
Can be overridden, though, in General Settings by selecting 'Show All Threads' under 'Default Thread Age Cut Off:'
This is the info I was looking for.
16th Jan 2013, 12:12 PM #8
Don't think so Peter
On mine, it is showing same as you too Humphrey and same for another Mod, so it isn't just you.
As posted before, has been reported for admin's attention.Cheers
DJ
ADMIN
16th Jan 2013, 01:04 PM #9Member
- Sep 2012
- Oz
- 51
Mine's fine now, after changing that setting as described in my last post. (Must be the default setting for the BS Box forum.)
Edit: Thanks for following up on this, DJ. I wasn't having a go at you earlier. I'm a bit blunt sometimes.
16th Jan 2013, 01:08 PM #10
16th Jan 2013, 01:11 PM #11Senior Member
- Jun 2003
- 326
DJ.
If I knew how to do a screenshot I could show you but mine shows Page 1 of 13 - Threads 1 to 30 of 363.
Thread Display Options - Show threads from the beginning. Sort threads by: Last post time. Order threads in Descending Order.
Seems no longer necessary others were faster then me.
Peter.
16th Jan 2013, 04:01 PM #12Member
- Sep 2012
- Oz
- 51
16th Jan 2013, 04:52 PM #13
Default setting has now been changed and from my check is now shows as Beginning
DJ
ADMIN
16th Jan 2013, 06:30 PM #14Member
- Sep 2012
- Oz
- 51
Thanks DJ.
I changed back to 'Use Forum Default' for 'Default Thread Age Cut Off' in my General Settings and can still see all threads from the beginning now.
I also logged off and had a look as a visitor - they now also see all posts in the BS Box forum automatically. Much more interesting than just two threads.
