Results 61 to 75 of 115
Thread: Upgrade 2012 - Problems & Help
16th Oct 2012, 05:55 PM #61Member
- Sep 2012
- Oz
- 51
Thanks Robbo. I still haven't found where Firefox stores bookmarks to do it manually.
MulgaBill - I used the method you pointed to, but it has the problem described earlier.
I haven't heard others mention this problem yet, but I do have more nested sub-folders in IE8 Favorites than most, to cover my various hobbies. This must be the reason Firefox couldn't import everything - probably only looks at sub-folders one or two levels deep.
16th Oct 2012, 06:26 PM #62Member
- Sep 2012
- Oz
- 51
After a bit more playing around, I found a method of copying all Favorites from IE8 to Firefox 16.0.1, including multiple nested levels of sub-folders.
The idea is to export the Favorites from IE8 to a HTML file then import that file into Firefox as Bookmarks. Forget their wizard, it's broken.
Note that for Firefox to 'see' it, it must be a .html' file, not '.htm'.
Method: -
First export the IE8 Favorites to a HTML file as follows: -
>File
>Import and Export
Check 'Export to a file', click [Next]
Check 'Favorites', or select folder, then click [Next]
Select a location to save the file and, importantly, change the filename extension of the saved file from '.htm' to '.html'. (Otherwise Firefox won't find it.)
Click [Export].
Next, in Firefox: -
>Bookmarks
>Show All Bookmarks (opens 'Library' window)
>Import and Backup
>Import Bookmarks from HTML
Browse to the HTML file and click [Open]
Close the 'Library' window.
All done.
16th Oct 2012, 07:10 PM #63
None of the uTube links posted prior the the upgrade appear to be working now. Is there an easy fix for this, or do the links have to be individually re-posted or edited so that they work?
http://www.woodworkforums.com/f124/n...-blues-111946/To grow old is inevitable.... To grow up is optional
Confidence, the feeling you have before you fully understand the situation.
What could possibly go wrong.
21st Oct 2012, 09:17 PM #64
Im unable to reply to threads or create new ones
THIS IS A TEST
21st Oct 2012, 09:21 PM #65
Now its not working again
21st Oct 2012, 09:22 PM #66
This is crazy
23rd Oct 2012, 08:39 AM #67Novice
- Oct 2012
- Victoria
- 10
Operating System: Windows
Operating System Version: 8
Browser: Chrome
Browser version: Version 22.0.1229.94
Date and time of the problem: 23 Oct 12
Description of the problem and other relevant information. I'm not sure if this problem is due to your upgrade or something I did wrong, but I cant see my thread or reply to it (http://www.woodworkforums.com/f11/ha...oor-ok-160860/)
23rd Oct 2012, 12:09 PM #68
Post is now visible. new posts are moderated if they have a link in them.
23rd Oct 2012, 12:41 PM #69
I Now Have Paragraphs
Sorry to side track the thread
But I now can use....
paragraphs!!!!!!!!!! Just the way I could before the "New" system. I can even now use smiley faces.
The only thing lacking seems to be the front page of threads that has a header full of notebook commands instead of the proper Forum header/directory.
Not whinging. Just reporting. If anyone was wonderingJust do it!
Kind regards Rod
23rd Oct 2012, 01:15 PM #70
I'm still having problems with marking the forums as read: When I click on Forum Actions > Mark Forums Read, the following message pops up...
"Your submission could not be processed because a security token was invalid."
I'm running Firefox 16.0.1 on Windows 7 Professional.
Neil was looking at this apparently known issue but I think he may have hit a wall (or was busy with a show or something)..
I know you believe you understand what you think I wrote, but I'm not sure you realize that what you just read is not what I meant.
Regards, Woodwould.
23rd Oct 2012, 01:28 PM #71
23rd Oct 2012, 01:47 PM #72Novice
- Oct 2012
- Victoria
- 10
23rd Oct 2012, 01:55 PM #73Novice
- Oct 2012
- Victoria
- 10
When I use to Admin a vBulletin forum we had this problem a few years ago, I only just joined this forum so I don't really have any idea what is going on. It seems like the Admins are upgrading the forums, for us it was a problem with the code which handled the session key its a fairly older problem but I guess it's still persistent. I'm sure the Admin's will be taking care of it.
23rd Oct 2012, 02:09 PM #74
23rd Oct 2012, 02:54 PM #75
The whole new forum seems to have stteled dow nicely (with isolated problems I guess), so "good job" to the team under trying circumstances.
Quite a while ago I posted in here that the refresh time was crazy, but nobody seemed to address that (or concur for that matter). I'm still finding that a refresh takes ages, and sucks the hell out of this end. "Mark Forums Read" is the biggest guts, and i can 100% look forward to it doing any of the following, almost every time:
preventing typing in an email (or post)
scrolling a window down
Changing tabs or other windows
This only happens with the forum. ABC News, Gmail etc all refresh/load etc in perhaps half to one second, and the forum is usually close to 30 seconds or more, and rarely less than 3-4 seconds
FF (the current, and best version)Regards, FenceFurniture
