Results 1 to 5 of 5
Thread: Why is this happening.
25th Aug 2009, 09:31 PM #1
Added by Robbo: Derek sometimes cannot access the links to some threads on the forums.
Still cannot.
This is not a new situation. It occurs with most links such as yours. I get the follow message ...
derekcohen, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Regards from Perth
DerekVisit www.inthewoodshop.com for tutorials on constructing handtools, handtool reviews, and my trials and tribulations with furniture builds.
25th Aug 2009, 09:44 PM #2
I received the same message for all four attachments. Once I logged in I was able to view them.
For some reason, following wheelin's link takes to to a place where your login is not recognised.
Wheelin's link:
http://www.woodworkforums.com./showthread.php?t=96290
25th Aug 2009, 10:16 PM #3
I am logged in (at the new end) and still cannot access the site.
Regards from Perth
25th Aug 2009, 10:40 PM #4
Hi All,
I log in using www.woodworkforums.com.au/ and just tried Wheelin's link above. It took me to the page in a new window but dropped me back to visitor. The images showed as files. Got the same message as Groggy got when I tried to open them.
I then entered my username and password and all the images appeared in the first post.
Do not know if this helps at all. Is a similar experience to Groggy but different experience to Derek perhaps.
Pops
26th Aug 2009, 12:01 AM #5
OK, it seems that some people have short memories, because you've asked for certain sub-forums to be blocked, you cannot access the link that Ray has put up, this is why you're receiving the message you've quoted.
If you do not wish to receive this message any more, you'll have to have all of the Sub-forums set back to default.Cheers
DJ
ADMIN
By Grumpy John in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 26Last Post: 21st May 2009, 08:02 AM -
What's happening?
By Waldo in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 2Last Post: 27th Jul 2008, 02:39 PM
