Results 1 to 5 of 5
20th Apr 2022, 12:03 PM #1New Member
- Apr 2022
- Gladstone
- 69
- 3
Beaver Mk2 Milling machine enquiry
Hi I've just bought a Beaver Mk2 milling machine and its missing a couple of parts. The main one being the external assembly for the High/low Speed change. It has a variable speed head if it makes a difference. I've found some photos of the removed components on another old US forum. The main part i'm interested in is called the 'Back Gear Lever' on pages 24 and 25 of the Beaver Manual. Its not really a lever but the hub that detents the speed positions. The speed change lever does screw into this.
Does anyone have a photo of the underside of this component?
Bob
22nd Apr 2022, 07:26 PM #2Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
I have the same machine but I can't access it at the moment, when I can, I will get some dimensions and photos for you.
25th Apr 2022, 12:54 AM #3Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
I have a PDF of the manual if wanted.
26th Apr 2022, 01:57 PM #4New Member
- Apr 2022
- Gladstone
- 69
- 3
26th Apr 2022, 02:00 PM #5New Member
- Apr 2022
- Gladstone
- 69
- 3
Gcode enquiry
By familyguy in forum CNC ForumReplies: 8Last Post: 13th Jun 2021, 09:14 PM -
Beaver Milling Machine Motor question.
By LexD in forum ELECTRICALSReplies: 5Last Post: 1st Oct 2020, 11:00 AM -
Small Flat Belt Pulley re Bobs enquiry
By Abratool in forum METALWORK GENERALReplies: 14Last Post: 10th May 2012, 06:46 PM -
Milling machine
By paulj in forum METALWORK GENERALReplies: 1Last Post: 8th Oct 2011, 10:14 PM -
Milling Machine
By R W in forum METALWORK GENERALReplies: 7Last Post: 17th Mar 2011, 09:02 PM
