Results 16 to 21 of 21
28th Mar 2023, 02:43 PM #16
Awesome, keep us posted.
1st Apr 2023, 06:14 PM #17Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
I used a 6mm reamer on the PLA gear's bore, to match the spindle's diameter.
For a positive drive, I installed a 1.5mm roll pin into the spindle, and put open-ended slots on the gear.
That method also makes it easy to remove and install new gears.
I'll put it on the motorbike tomorrow and, weather permitting, take it for a trial run.Last edited by nadroj; 1st Apr 2023 at 06:16 PM. Reason: mistake
2nd Apr 2023, 03:00 PM #18Mechanical Butcher
- Oct 2004
- 1,894
A little more progress - the drive assembly is installed to the wheel, ready to test.
I have some silicone paste for electrical use, so I used that for lubricating the gears (plastic to metal) as it's greasy stuff.
I'll keep an eye on it in case it melts in use.
The spindle turns when the wheel is spun. That in itself is promising, as I made some guesses for working out the gear's required helix angle.
I've run out of time today, and will report further when I've had a chance to go for a ride.
10th Apr 2023, 07:33 PM #19Mechanical Butcher
- Oct 2004
- 1,894
Today I took the motorbike for a 50km ride to test the speedo operation.
It works fine, so far.
After some more distance, I'll disassemble the speedo drive gearbox, inspect and report here.
3rd Sep 2023, 02:23 PM #20Mechanical Butcher
- Oct 2004
- 1,894
Weather is getting better for motorbike riding, so I added another 70km on the odometer today.
Total = 120km on the new printed plastic speedo drive gear.
It's functioning well so far.
Jordan
12th Nov 2023, 06:18 PM #21Mechanical Butcher
- Oct 2004
- 1,894
I went for a weekend ride, now have 300 kilometers on the PLA gear.
It has worked perfectly so far.
Removed and cleaned, result is a slightly more furry-looking gear, with wear on the ends of the helical teeth.
The wear is on the opposite sides, compared to the original steel gear, and about the same worn width of about half the tooth flank at the ends.
It is progressively less towards the centre, where there is evidently no wear.
My guess of 40 degrees instead of the original 30 may need to be adjusted to 35 degrees, for a better result in future.
I will use the PLA gear until failure. It may be that it'll last long enough to put up with regular new replacements.
It is very easy to remove and replace.
It's nice knowing that the steel worm gear it meshes with won't be distressed by the soft plastic imperfect gear.
Wanted: Small/medium Sized Geared head Lathe with quick change gear box
By ml018 in forum WANTED TO BUYReplies: 0Last Post: 13th Apr 2018, 07:45 PM -
Where to find small gear cutters
By Michael G in forum METALWORK GENERALReplies: 3Last Post: 28th Sep 2016, 03:39 PM -
VSD suggestion
By BobL in forum METALWORK GENERALReplies: 28Last Post: 24th May 2011, 01:16 AM -
Suggestion
By NewLou in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 3Last Post: 8th Jan 2005, 03:37 PM
