Results 31 to 37 of 37
18th Dec 2024, 04:43 PM #31Senior Member
- Sep 2019
- Newcastle, AU
- 245
This was one I was satisfied with making last month... our wireless access point started getting flaky and dropping out regularly, and with two people that work from home here that was getting tedious. Upon investigation it was far too hot to touch, and if it was turned off and let cool down it operated fine... for a while, until it got hot again.
I had a silent-running Noctua fan from an old server laying around and figured I'd chuck something together to make a little cooling stand for it and see if it made any difference. The design:
Underside - the fan goes in the square recess and screws into heatset inserts which are installed from above:
Printed and under the AP:
Works a treat - the fan is inaudible and now the unit is cool to the touch at any point in the day. Printed in blue sparkle ABS. Draws air in at the bottom and pushes it out against the underside of the AP.
11th Jan 2025, 05:56 PM #32Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,746
Need a round over die set for the bead roller so I can make some rear wheel tubs. Should be an interesting experiment to see if they hold up or break on the first use.
11th Jan 2025, 06:51 PM #33Diamond Member
- Mar 2014
- South of Adelaide
- 1,312
11th Jan 2025, 07:38 PM #34Most Valued Member
- Mar 2011
- 1,746
Pla+
11th Jan 2025, 07:51 PM #35
PLA will hold for a few bends easily.
Just add like 8 or 10 outer perimeters.
You just need to print in the orientation that will give you maximum shear strength at the bending face.
11th Jan 2025, 08:25 PM #36Most Valued Member
- Mar 2011
- 1,746
They are solid prints with alternating directions of travel each layer.
Im expecting I’ll get sufficient mileage out of them without too much drama
13th Jan 2025, 08:00 PM #37Senior Member
- Sep 2019
- Newcastle, AU
- 245
I wanted to make a Milwaukee cyclone separator work with a Bosch extractor... two adapters later and it works.
Works a treat.
Scaling a print
By BobL in forum 3D Printers and PrintingReplies: 12Last Post: 25th Oct 2022, 02:58 PM -
Can I print a thread with pictures
By ClintO in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 2Last Post: 27th Apr 2013, 12:20 PM -
Think twice before being too judgemental, and then think again before going to print.
By Ropetangler in forum METALWORK GENERALReplies: 25Last Post: 30th Sep 2012, 01:08 PM -
Print size
By nine fingers in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 10Last Post: 29th Jul 2012, 10:38 PM -
Finding Engineering Design Software For Automatic Machine Design
By davidWilliams in forum METALWORK GENERALReplies: 2Last Post: 11th Jan 2010, 10:41 PM
