Results 1 to 4 of 4
    Dec 2007
    Adelaide
    574
    Default 3D modelling the easy way
    I've got a project underway and plan to use a 1:1 drive using HTD5 timing belt and pulleys - first port of call was Ebay to see what was being offered, would anything there suit ? a fruitless hour later I thought, I've got a cnc mill why not make them, which led me to this youtube video, creating a traceparts account was easy and 5m min later I had my pulley on the fusion360 screen, another 5min to make a few changes and it was ready for 3D printing or machining, well worth a look, not only for pulleys but any mechanical or electrical part you may need to model.
    Easy! How to create HTD5M Pulley in Fusion 360 - CAD Tutorial - YouTube
    7,189
    Nice one.
    I've been designing a range of Bell Mouth hoods for dust extraction - I've only printed a couple.
    Because they have a 3D curved surface finish is an issue - still working on those.
    I'll post some pics in another thread.
    6,475
    Quote Originally Posted by familyguy View Post
    Hi, FamilyGuy,
    Thank for your interesting post. Since I'm about to start designing a small pulley like the one in your picture to drive the toothed belt for my stone tumbler project. In my case I propose to machine it out of aluminium rod or Acetal plastic bar. It will be designed to fit on a 6 mm diameter shaft and about 16 to 18 mm diameter, probably around 6 mm thick.
    I'll post the drawing in the "Pebble Tumbler" thread along with pictures.
    Jun 2005
    Helensburgh
    618
    Hi, FamilyGuy,
    If you can't make Gilmer belt style pulleys Small Parts & RS Components have an excellent range along with belts to suit.
    Small Parts & Bearings
    Buy belt online from RS Components (rs-online.com)
    CHRIS
  1. Hobart Easy Tig
    By gazza2009au in forum WELDING
    Last Post: 6th Sep 2019, 11:19 PM
  2. The modelling thing
    Last Post: 24th Oct 2011, 09:47 PM
  3. Easy Outs
    By mat in forum METALWORK GENERAL
    Last Post: 12th Jun 2005, 06:38 PM
