Results 1 to 5 of 5
Thread: 3D printing or 3d welding?
15th Sep 2021, 09:39 AM #1Most Valued Member
- 4,255
15th Sep 2021, 11:14 AM #2Member: Blue and white apron brigade
- 7,183
There are a number of technical terms bandied around for the process in the vid, one is FDM (fused deposition modelling) another os FFF (fused filament fabrication).
3D printing with plastic filament is often called FDM.
Welding could also be considered a form of FFF.
Welding using involves joining two pieces of metal but, adding runs of hardened steel over front end loader bucket edges etc is also called welding.
15th Sep 2021, 04:39 PM #3
Well there is no doubt that one metal is being fused into another,so it is welding
Is it really 3D though ?
Its the nomenclature or the semantics which are in doubt.
Looking back into the industrial pas,welded metal being deposited in a spiral circle is is nothing new.
GMAW, (Mig to most) sub Arc and Tig processes have all being utilised in some form of rotated positioner to lay down beads.
These processes are the roots of the new system
The new process is merely a synergy of technique and application from a couple of different processes.
CNC control is overlayed on a mechanical jig,plus some pulse type control over arc duration.
It is in need of a more descriptive name than what has been suggested.
7th Nov 2021, 04:16 PM #4New Member
- Nov 2021
- North Manly
- 77
- 3
3D printing or welding
I have read that 3D printing metals has opened up the ability to create compounds of previously impossible to mix metals. Mixing on an atomic scale appears to overcome the reluctance of previously incompatible metals to fuse. Think of the possibilities!
8th Nov 2021, 09:00 AM #5
Hi Thinker,
Welcome to the MetalWork forums,
We have great bunch here very helpful and supportive of one another. You will find many like minded folk here with same interests as you.
If you explore our pages you will find bits and pieces of interesting things all over the place.
Go to the FORUM box at top LH corner and click on it.
A drop down menu appears and you can select Forum Home at the top of the drop down menu list. Scan down the pages to look at what we have.
Please make an effort to read the Terms of Use -our Rules - pretty standard for many forums these days.By joining the forum its automatic that they apply to you as a member.Not having read the the TOUs won't be of help if someone does not follow them.
Sometimes the soft ware works so you can't post pics or links until 10 posts are made ( or such links and pics are cleared by a mod)
Its anti spam thing.
There are all sorts of forums that might be parallel with your interests, found as described above.
Welcome
3D printers - what are you printing for the workshop?
By OxxAndBert in forum METALWORK GENERALReplies: 47Last Post: 18th Mar 2021, 05:26 PM -
Not metalwork but CNC: SLA 3D printing
By pippin88 in forum CNC ForumReplies: 3Last Post: 20th Sep 2020, 11:04 PM -
More 3D printing
By Michael G in forum CNC ForumReplies: 0Last Post: 28th Feb 2017, 07:09 PM -
printing of threads
By eskimo in forum METALWORK GENERALReplies: 7Last Post: 25th Jul 2012, 09:25 PM -
Printing out an Arc-Welding Tutorial...
By Batpig in forum WELDINGReplies: 10Last Post: 24th Feb 2009, 07:42 AM
