Results 1 to 3 of 3
26th Feb 2023, 01:43 PM #1Most Valued Member
- 2,671
Using a Dynabolt for an expanding tool
The other day I had a need for a puller to remove a blind pilot bearing from a crankshaft.
For plain bushes I normally just pack the bore and use a close fitting punch to hydraulic the bus out - but this one was a needle roller bearing with a closed back.
After a quick head scratch I ended up with this arrangement to expand behind the needle rollers of the bearing.
I used the inner part of 10mm dynabolt to do the expanding. They are a decent grade of steel and already have a thread on one end and a taper on the other.
I didn’t even bother to match the taper on the matching part of the tool - just made decent 45deg internal chamfer.
Same concept could be used for various other expanding grip applications.
26th Feb 2023, 02:04 PM #2I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,297
I like it. But I think your surface plate has seen better days....
26th Feb 2023, 04:01 PM #3Most Valued Member
- 2,671
Thankfully it’s only a floor lamp base!
I’m rough, but not THAT rough
Expanding 5C collet collection
By Boris Ludwig in forum THE HERCUS AREAReplies: 11Last Post: 13th Aug 2021, 08:02 PM -
Hercus 260 quick change tool post and tool size
By Shaun@27 in forum THE HERCUS AREAReplies: 13Last Post: 24th Apr 2021, 10:45 AM -
WTB Rovi 5C expanding Collets
By Boris Ludwig in forum WANTED TO BUYReplies: 0Last Post: 30th Dec 2020, 09:50 AM -
expanding alloy extrusion
By perrycas in forum METALWORK GENERALReplies: 14Last Post: 25th Oct 2020, 02:05 PM -
Parting tool mounted on rear tool post advice needed
By colbra in forum METALWORK GENERALReplies: 17Last Post: 12th Feb 2012, 02:49 PM
