Results 1 to 2 of 2
Thread: Filing a round bar
27th Oct 2022, 10:03 PM #1
Filing a round bar
Reidy41 posted about his Richardson drill press and it was mentioned in subsequent posts about possible nicks and damage to the round bar belt tension adjustment rods.
If such damage is to be repaired obviously a file may come into this repair.
That has triggered a memory of what one of my bosses once showed me. i was working in Queensland Alumina as a maintenance fitter and had occasion to file the dings from a round bar.
A long story made short is that he showed me the correct way to file a round bar and keep it round.
The file stroke starts with the leading edge of the file and the handle held higher than the front edge.
As the stroke progresses the file handle is moved lower finishing with the handle being below the forward .
In one stroke the file is able to cover a good portion of the part circumference edge of the round bar.
Some members may have heard of this one but perhaps there are some that haven't.
27th Oct 2022, 10:57 PM #2Most Valued Member
- 5,945
Thanks Grahame, your comment is timely, as I'd forgotten about that trick
Filing small grooves in bolts
By shivasage in forum METALWORK PROJECTSReplies: 7Last Post: 8th Sep 2020, 09:22 AM -
Brass Round bar etc.
By wm460 in forum METALWORK GENERALReplies: 5Last Post: 6th Apr 2020, 08:54 PM -
Useful ? Circular lathe mounted filing disc
By steamingbill in forum METALWORK GENERALReplies: 24Last Post: 21st Mar 2019, 09:44 PM -
Where to buy cast round
By morrisman in forum METALWORK GENERALReplies: 22Last Post: 3rd Dec 2015, 12:55 PM
