Results 1 to 8 of 8
    Jul 2021
    Europe
    30
    36
    Default Removing epoxied in large diameter threaded rods from concrete
    Usually at my job, we just cut them at the base, move 50mm to the side and drill a set of new holes. 30mm holes. that thing is not forgiving if it decides to bite the concrete, your body breaks before that machine does
    with any problem there is a solution, and this time it was actually really easy
    you just take a piece of tube a forklift can go into, weld the respective nut onto it (very durable welds) and then you screw it on the end of the threaded rod sticking out of the ground, then you go as deep into it with the forklift as you can and carefully lift it up. just when you think it didnt work it will jump up a bit, jerking it a bit back and forth, from side to side helps. if its a bad day the bolt snaps.
    other ideas for removing these bastards are very welcome, i do see potential in some kind of a bolt device with this but i cant quite imagine it yet. maybe torching them so the epoxy gives up would work? if you can unplug all of these you dont have to drill in new holes in the ground- we use these for securing beams that hold the conveyer belts, it happens that a large machine runs them over- effortlessly.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    That was a little bit clearer than mud.
    We don't have or make tube big enough to drive a fork lift into in Australia, it would all need to be fabricated.
    7,189
    Heating the rods should soften the epoxy.
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by Zeth4500 View Post
    Hello Zeth. If you are reusing the existing holes, why are you replacing the bolts?
    near Rockhampton
    6,218
    Must have been a sub standard job of putting the bolts in. Done properly they should rip out the concrete.
    Jun 2007
    Ipswich QLD
    68
    1,997
    An oversized easy out?
    Oversizetd left hand drill?
    Cryo freeze the bolt hit it with a jack hammer hope it shatters. Or larger shifter undo it.
    Sent from my SM-T580 using Tapatalk
    Nov 2007
    melbourne australia
    3,228
    Yep. I hope they drill out the old epoxy before gluing them in again. And thoroughly remove all the concrete dust. Otherwise the whole exercise will be a WOFTAM.
    Jul 2021
    Europe
    30
    36
    the bolts are usually bent, they hold down a 20mm steel plate which has a 200x200 pipe ontop, and if it needs replacing then its because a front loader rammed it
    we do have large keys designed to be hit by a hammer, but theyre situated 200mm into the concrete, plus i would have to bring a welding machine to do the job, and welding rods, and welding helmet, and get permission to use fire hazard tools, and ventilation gear
    i could then maybe use a large fasterner but the biggest one we have runs on air pressure, i do normally bring an air pressurizer to blow the holes clean from dust- but anything turning the threaded rod might not work as its an irregular hole with epoxy concrete glue in it
    a real sub-par job is to do it when its raining, my boss told me it wouldnt be a problem, but the epoxy didnt bind one slight bit, so that was half a day wasted- im paid by the hour luckily.
  1. Large diameter fly cutter
    By Ajax01 in forum METALWORK PROJECTS
    Last Post: 30th Jul 2021, 08:00 PM
  2. Removing a large flatbelt pulley from a 7.5HP motor
    Last Post: 1st Nov 2020, 07:20 PM
  3. Replies: 8
    Last Post: 1st Sep 2014, 12:26 PM
  4. Home made large diameter fixed steady
    By nearnexus in forum METALWORK GENERAL
    Last Post: 5th May 2013, 08:59 PM
  5. What Diameter for threaded rods/shafts etc
    Last Post: 7th Nov 2012, 07:48 PM
