Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Jul 2021
    Europe
    30
    36
    Default Jeweling/circle polish tool, done very easy
    so the problem with putting this tool together has always been attaching the damn scotch brite. just to explain what this tool, its an abrasive tool thats inserted into a drill press (it doesnt work with hand drill) and its forced against a metal plate in which the abrasive grinds the surface to cause a circular pattern
    many methods have been devised for this, velcro, glue, rolled up sandpaper in a small pipe etc, but i have not yet come across something similar to what i eventually managed to throw together
    the construction is simple. M16 threaded rod, disc at the bottom, 2 M16 nuts
    its constructed by first putting on a nut and then positioning the nut so that it keeps the disc just a bit above the threaded rod so you get a bit of a gap to fill out with welding
    we have sold off our lathe, but i found it that carefully grinding the end on belt sander works well if you just keep light grip with left hand and use right hand to kind of "stroke" it to rotate, otherwise you may be able to cause the belt grinder hitting the threaded rod to cause the rotation itself but you need a piece of metal to push against it with to cause very low friction with the object you apply pressure with
    next up you put a piece of scotch brite around the disc so that it touches the threaded rod, a nut, and preferably a disc is then put on the threaded rod so that it keeps the scotch brite into place
    this system is very easy to work with as you can very quickly change scotch brite- but really you rarely have to do this as you can simply grind the outer layer of scotch brite on a belt grinder and the scotch brite will go an extra mile
    you can get a large plate finished fast if you crank the drill press up to 3000rpm and dont clamp it down.
    Jun 2011
    gold coast
    303
    HI Zeth,
    I'd love to see some pics of the jewelling results your tool makes please
    Aug 2019
    Revesby - Sydney Australia
    56
    1,183
    Quote Originally Posted by Briangoldcoast View Post
    Bottom of the second photo?
    Dec 2007
    Sydney
    395
    This is engine turning isn’t it ?
    Done bit using a dowel and grinding paste from memory.
    H.
    Jimcracks for the rich and/or wealthy. (aka GKB '88)
    Jun 2007
    Ipswich QLD
    68
    1,996
    Looks great something I've always admired yet to have a go.
    Sent from my SM-T580 using Tapatalk
    Nov 2007
    melbourne australia
    3,228
    Here are some notes on the subject I found, but haven't yet tried.
    Attached Files Attached Files
    Apr 2013
    Mornington Peninsular
    23
    A 3M roloc scotch brite pad with a roloc drill arbor does the same thing as far as I can see. That’s what I use.
    https://www.3m.com.au/3M/en_AU/p/d/b40064719/
    Leigh
    Sent from my iPad using Tapatalk
    Jan 2004
    Mackay North Qld
    6,446
    There needs to be some form of jigging to :
    Keep the swirls in a straight line
    and have a method to equally space the "jewels".
    If either of these are overlooked the results can look pretty crappy in a larger size unit.
    We found this out in doing an aluminium jeweled dash for a race sports car.If the x + y increments are not kept equal it sticks out like DB's.
    Nov 2007
    melbourne australia
    3,228
    Quote Originally Posted by Ambrosia View Post
    That’s what I use.
    can you please tell me what grit you use? And given you live in my neighbourhood, where you get them from?
    TIA.
    Jul 2021
    Europe
    30
    36
    yes i havent quite figured out how to make a simple machine for dishing out maybe 20mm of spacing with a single click, i just do it by hand and it takes quite some concentration to get it well. but ive managed to do that, simply positioning the jeweling tool just outside the center of the last jeweling circle
    it also works well on zincplated parts
    interesting with the steel wire brush
    one interesting thing is that if you glue it on, you can have maybe 50mm plate that you attach the scotch brite on, but if you only attach 10mm piece of scotch bright dead center, you will make 10mm jeweling
    the wire brush seems perfect for making smaller jeweling, which is oftenly very difficult to me since i have used rolled up sandpaper stuck in a small metal pipe- and i did make a small configuration for this where you can push out the sandpaper using a screw on the top to get more "milage" and at the same time able to mount it in a drill press
    my boss usually complains about me making "weird" stuff, but this one plate for our bandsaw he havent yet complained about- i take it hes simply baffled haha.
    you need to see it in motion to really get the gist (video underneath)
    https://gyazo.com/07008e074d8e846755e5d8607025ceff
    7,182
    An X/Y vice/table would produce a pretty regular spacing.
    Apr 2013
    23
    I bought the roloc arbor from Total Tools as a kit with some sanding disks. I used the blue pad - no idea what grit.
    My first attempt:
    As Bob suggests, trying it on the drill press was hopeless. Used the y axis on the mill with a DRO for overlap.
    Leigh
    Nov 2007
    melbourne australia
    3,228
    Here's a pretty good video on the subject. Includes using an X-Y table with DRO.
    https://www.youtube.com/watch?v=DY7sCiahxHA
    Nov 2007
    melbourne australia
    3,228
    Thanks. The blue is 240 grit.
    https://www.totaltools.com.au/123449-pferd-50mm-very-fine-quick-change-surface-conditioning-disc-combidisc-5pc-47200083
  15. #15
    Jan 2004
    Mackay North Qld
    6,446
    There is some extra material I found.
    I have been looking at some early pics of the Spirit of St. Loius aircraft.
    It s is beautiful compared it to some other jewelling.
    Here is some more information on setups.
    https://ezinearticles.com/?Engine-Tu...uide&id=622286
  1. Easy made Tapping Tool
    By KBs PensNmore in forum METALWORK GENERAL
    Last Post: 30th Nov 2019, 09:57 PM
  2. easy diamond tool height setter
    By texx in forum METALWORK GENERAL
    Last Post: 24th Jul 2014, 12:04 AM
  3. What's the Best Way to Polish Checker-plate
    By zuffen in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 26th Jun 2012, 07:25 PM
  4. How to polish brass to mirror finish?
    By wsal in forum METALWORK GENERAL
    Last Post: 11th Nov 2011, 02:52 PM
  5. Iosso metal polish
    By R. McCarthy in forum METALWORK GENERAL
    Last Post: 29th Jul 2008, 12:20 AM
