Results 1 to 1 of 1
Thread: Tapping guides
24th Jul 2021, 09:36 PM #1Most Valued Member
- 2,651
Tapping guides
Very simple one that I’m sure a lot of you already use…
Many moons ago when I did basic workshop practice, we were taught to use a square when hand tapping holes - to ensure the tap stays squar to the workpiece. Good in theory but in practice it sucks.
These days when I have to hand tap I use a guide to get the tap started square.
Basically drill a hole of the same size as the thread - ie for M5 use a 5mm hole - in a piece of scrap stock at least 3-4 times as thick as the hole diameter.
Sit it flat on the work over the hole to be tapped, poke your tap through and as long as the hole in your block is square the tap will stay square.
Here’s one I knocked up today for some M5 holes.
Small round offcut, faced and recessed the center a bit (stops the guide sitting up on any burr around the hole, then drilled 5mm through.
Hit it with a number punch so I know what size it is for next time.
Hardened Drill Guides
By KBs PensNmore in forum WANTED TO BUYReplies: 8Last Post: 7th Sep 2020, 09:07 PM -
Guides for installing and setting up a mill?
By takai in forum METALWORK GENERALReplies: 3Last Post: 25th Mar 2020, 08:21 PM -
valve guides
By morrisman in forum METALWORK GENERALReplies: 20Last Post: 13th May 2017, 06:13 PM -
Help with tapping
By snowyskiesau in forum METALWORK GENERALReplies: 20Last Post: 21st Sep 2009, 03:41 PM -
Hydraulics - learning guides
By Clinton1 in forum METALWORK GENERALReplies: 7Last Post: 22nd Oct 2005, 12:34 AM
