Results 1 to 10 of 10
    6,475
    Thumbs up Bearing removal from a blind hole !
    How to remove a ball race from a blind bore came up on another forum recently which reminded me of a method that I used to remove one.
    I turned a piece of rod down to be a tight push fit into the bore of the bearing and drilled a tapping size hole down the centre. I then cut a slit in the end just longer than the bearings width with a hacksaw and squashed the slit closed at the end using a vise, after which I threaded the hole keeping the slit closed with the vise.
    Using a bolt and putting my just made extractor into the bearing bore and tightening the bolt, thus expanding the slit rod end to tightly grip the bearing, using a hooked slide hammer to remove it. A little heat on the outside helps as well.
    Dec 2018
    NSW
    586
    The trick with pilot bearings on vehicle clutches is to get a tightly fitting dowel and packing the hole with grease. Hammer it in and repack grease as necessary to hydraulically drive out the bearing.
    You can play with grease viscositites to account for different tolerances. I've even heard of guys tearing up bits of bread to achieve the same outcome.
    Apr 2018
    168
    Quote Originally Posted by Commander_Keen View Post
    Or wet paper towel.
    Oct 2004
    Southern Highlands NSW
    1,898
    In a hurry once, I removed a ball race from a dead-end hole in a light alloy case, by welding a threaded rod to the inner race.
    Then I could pull it out, and no harm done (except to the bearing).
    I now have a really cheap Asian blind bearing puller set with slide hammer included. It works sometimes.
    Nov 2008
    North Brisbane. Qld. Australia
    70
    1,513
    I have a proper blind hole bearing puller set, but before that have even used a dynabolt.
    Nev.
    near Rockhampton
    6,218
    I have used swear words.
    didn't work.
    Jul 2006
    Athelstone, SA 5076
    4,258
    didn't work.
    Nor me.
    It lessened the stress tho
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    I did once use the 'weld inside the race' method and it worked surprisingly well.
    Nov 2017
    Geelong, Australia
    57
    2,671
    Hi John. I must be misunderstanding what you mean, as can't get my head around how that could work.
    If you squeeze the slit end while threading won't you take more material out of the split section with the tap - resulting in a clearance to the bolt thread when it relaxes back to parallel? How would the bolt expand it?
    The only way I can see it being able to expand and grip the bearing bore is if there was LESS material taken out of the split section by the tap, which would either require expanding the split end while tapping, or using a tapered tap and not cutting a full depth thread into the split section.
    6,475
    Hi Steve,
    The screw down the middle pushes the taper apart causing the plug to grip the bearing bore.
    Argh I've just re-read what I wrote, yes you are right, I've got the work order wrong.
    Thread the bore and then squash it.
    I'm going to blame it on brain way ahead of my fingers, or something like that.
    Thanks for pointing it out !
  1. Removing blind rolled pin
    By KBs PensNmore in forum METALWORK GENERAL
    Last Post: 15th Jan 2019, 09:24 PM
  2. Porta-power for general pressing and bearing removal/fitment etc
    By OxxAndBert in forum METALWORK GENERAL
    Last Post: 17th Nov 2018, 12:43 AM
  3. Removing bearings from blind holes
    Last Post: 4th Apr 2016, 01:18 PM
  4. Tapered Roller Bearing Cup Removal
    Last Post: 17th Dec 2013, 02:14 PM
  5. Blind Hole Spotters
    By colbra in forum METALWORK GENERAL
    Last Post: 25th Aug 2012, 08:21 PM
