Results 1 to 3 of 3
Thread: Cheap TCT slitting saw
23rd Jan 2021, 02:45 PM #1New Member
- Jan 2021
- Albany WA
- 2
Hello, this is my first proper post here though I've been lurking for a while.
A few years back I bought a pair of TCT blades for the Ozito plunge saw (24T x 89 mm x 10 mm, about 1/16 kerf) for a project that never happened. Today I though I'd try one as a slitting saw to cut 25 mm deep slits in 8 mm mild steel.
Worked like a charm. I mounted it on my home-made 10mm arbor (18 mm OD) and stuck it in a collet on the old mill/drill. After a little experimentation I found it cut happily at about 250 RPM lubricated with squirts of WD40.
Given the tolerances here and there most of the teeth weren't doing any work, so between slits I loosened the fixing bolt on the arbor and rotated the blade a bit in the hope of evening the wear. (The arbor is home made, 16 mm OD at the business end.)
At about $13 for a pack of two these blades seem like a good value where precise thickness isn't an issue.
23rd Jan 2021, 07:43 PM #2
Hi, I've been doing a similar thing with those cheap 125 mm TCT saw blade out of Aldi and Lidl ! Very good value. I've found that the blades are quite well centred and don't wobble up and down making the cut wider than it needs to be. I've used mine on both the lathe and mill, but at 450 rpm the drill press is a bit too fast for safe working.
24th Jan 2021, 08:53 AM #3Pink 10EE owner
- 6,216
Pictures or it never happened.
Cheap Protection from Super Cheap.
By Anorak Bob in forum METALWORK GENERALReplies: 4Last Post: 30th Apr 2014, 12:01 AM -
Slitting saw keys
By Ueee in forum METALWORK GENERALReplies: 6Last Post: 17th Feb 2013, 11:45 PM -
Slitting Saw Holders
By Jors in forum METALWORK GENERALReplies: 3Last Post: 10th Dec 2012, 09:47 AM -
Cheap vices at Super Cheap Auto
By LordBug in forum METALWORK GENERALReplies: 19Last Post: 5th Jun 2011, 01:14 AM -
MT-3 slitting saw arbors
By hitachi230 in forum METALWORK GENERALReplies: 7Last Post: 3rd Jun 2008, 12:16 PM
