Results 1 to 1 of 1
Thread: 6X4 Bandsaw Speed Hand Wheel
16th Jan 2021, 11:38 PM #1Most Valued Member
For those of us with a 6X4 Bandsaw (or any other sized bandsaw), going from cutting a bit of 3mm on edge to cutting 150mm on its flat, can be very time consuming. I had this idea of fitting an Allen key of the correct size into a cordless driver drill, to speed up the process.
It works well, just have to remember to slow start the wind out as it will unscrew the bolt.
This idea should also work for those that have a hex headed bolt, just grab an elcheapo socket and weld a bit of bar to fit in the drill if you don't have 1/4" hex adaptor to suit the socket.
HTH
BECON 2-Speed Hand Drill
By Ray-s in forum ANTIQUE AND VINTAGE MACHINERYReplies: 3Last Post: 7th Aug 2021, 12:19 AM -
bandsaw speed
By shaper07 in forum METALWORK GENERALReplies: 6Last Post: 16th Feb 2020, 03:54 PM -
Bandsaw blade speed.
By BaronJ in forum METALWORK GENERALReplies: 15Last Post: 2nd Feb 2018, 11:43 PM -
hand wheel question
By texx in forum METALWORK GENERALReplies: 7Last Post: 1st Nov 2011, 08:06 AM -
left hand wheel studs
By leopardwood in forum METALWORK GENERALReplies: 19Last Post: 20th Jul 2010, 10:46 AM
