Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    6,473
    One of the reasons that I like my pyramidal shaped one is that the point is very sharp which make it easy to find a scribed line or intersection. Its also easy to touch up the flat sides. The conical point on the normal ones tend to round off particularly if you are heavy with the hammer blows.
  2. #17
    Oct 2004
    Southern Highlands NSW
    1,898
    Is it tricky to grind a pyramidal point, in terms of getting all flat surfaces to intersect perfectly at the point?
    For a conical point, I chuck a centre punch in a pistol drill.
  3. #18
    6,473
    Hi Jordan,
    No I would say not ! I've never had any problem, but I do use a 45 degree angle plate on the DE bench grinder table as a guide.
    The harder part might be deciding whether you want three or four sides to the point. My punch was originally purchased with three sides, so all I do to touch it up is set the flat to match the side of the wheel, though I have occasionally stoned the flats to get the tip sharp again after being a bit heavy handed with the hammer. The trick is to treat it like a prick punch and re-punch with a normal cone tipped punch if you want a larger marking.
    The only other thing I would mention is hardness ! Because the tip is so small its easy to destroy the hardness when grinding, so you have to be careful not to overheat it.
  4. #19
    Jul 2021
    Europe
    30
    36
    Default drill sharpening with hand drill
    if a drill fits in a hand drill, and you can really FUBAR'd it, skewing the sides up or messed up the angle you can use this trick
    ideally you wanna run it counter clockwise while sharpening it on band grinder so it doesnt bite into the belt itself
    you can adjust the angle of the tip with this and both sides will be equal lenght. then you just gotta touch both sides to get the cutting part of the drill done
  5. #20
    Jul 2021
    Europe
    30
    36
    indeed making it 3-4 sided helps, reference arrows used for hunting.
    one place i worked we had to make some sharpened rods for penetrating something- i truly cant remember what the hell it was, but the conically sharpened spears didnt do much, but the ones that were 3 point or was it 4 point went right through, because as it expanded the material, the points would make a weakpoint and actually cut the material, causing it to breach and break rather than expand while adapting and pushing against- if that makes any sense
    i believe it was some kind of fabric we had to punch through, but on the nano scale im sure steel can work the same way but surely wont "cut" as easily
  1. Automatic Centre Punch
    By Twisted Tenon in forum METALWORK GENERAL
    Last Post: 27th Sep 2017, 01:27 PM
  2. Sharpening Spring Loaded Centre Punch
    By Fuzzie in forum METALWORK GENERAL
    Last Post: 29th Nov 2015, 04:06 PM
  3. Optical centre punch for 'simonl'
    By Steamwhisperer in forum METALWORK GENERAL
    Last Post: 30th Aug 2012, 06:11 PM
  4. Optical centre punch
    Last Post: 9th Aug 2012, 01:16 AM
  5. Centre punch mark magnifer
    Last Post: 18th Jul 2007, 01:59 PM
