Results 1 to 1 of 1
Thread: Trailer wiring
17th Dec 2020, 11:50 PM #1Most Valued Member
- 72
- 6,181
Trailer wiring
When running wiring inside a trailer chassis, I use MIG wire with a short (300mm) length of fluorescent brickies stringline. The string always sits at the bottom and is easily seen because of the colour, making it easy to pick up with a wire hook. The end of the MIG wire is threaded into the wire, approx. 40mm, have it protrude and make a right angled hook to sink back into the wire, a layer of plastic tape makes the wire come out of the hole easily, as it's tapered to a point, and prevents the MIG wire coming off.
Hope this helps someone.
24V to 12V wiring
By .RC. in forum TRAILERS & OTHER FABRICATED STUFFReplies: 23Last Post: 20th Dec 2017, 10:27 PM -
Hercus wiring
By Stephen Gorton in forum THE HERCUS AREAReplies: 3Last Post: 26th May 2015, 10:06 AM -
Wiring junctions?
By Legion in forum TRAILERS & OTHER FABRICATED STUFFReplies: 6Last Post: 22nd Oct 2013, 09:13 PM -
Hendey wiring
By morrisman in forum METALWORK GENERALReplies: 7Last Post: 4th Apr 2012, 07:38 PM
