Results 1 to 5 of 5
    6,443
    Thumbs up Brass tip in Grubscrew !
    Just passing on a tip given to me by Kryn.
    A tip I picked sometime ago, was to drill the end of the grub screw and place the little brass screws from electrical fittings in, so they don't bite into the shaft, as even without serrations, they still bite into it. DAMHIKT.
    Drill the hole slightly smaller than the shaft of the screw and hammer them in.
    Thanks Kryn
    Nov 2007
    melbourne australia
    3,228
    Another method I've seen, but not tried, is to grind a nice clean flat on the tip of the grub screw then braze a big blob of bronze onto the screw. Then turn the blob down to something more pretty.
    Adelaide
    68
    1,373
    This works well, especially using TIG brazing as the control over the size of the deposit is excellent. With practice you can get it such that no final machining is required.
    Oct 2008
    Cairns, Q
    666
    I have often done this - not a big blob though - only a small amount. If the screw is long enough I screw an old button die or die nut onto the screw first. Then when you unscrew the die it cuts a perfectly aligned thread in the bronze, and no further machining is usually required.
    Frank.
    Nov 2017
    Geelong, Australia
    57
    2,651
    Tried the TIG and button die method today and it worked well.
    I also put the button die in a handle and used the earth clamp to hold it to the table which made it really easy to get it in a good position, and great earth contact.
    I forgot to grab a photo of the die and handle setup but here is the end result.
  1. what rods for thin brass to brass ??
    By Mathuranatha in forum WELDING
    Last Post: 23rd Nov 2020, 08:17 PM
  2. VICTORIA Brass Flat Bar Assorted Sizes & 1/4" SWB Threaded Rod & 260 Carbide Brass Sheet
    By thumbsucker in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 18th Mar 2013, 03:36 PM
  3. 5/16 Brass
    By rogerbaker in forum METALWORK GENERAL
    Last Post: 11th Nov 2012, 10:57 PM
  4. brass
    By tanii51 in forum METALWORK GENERAL
    Last Post: 22nd Aug 2009, 09:21 PM
  5. Brass on Brass
    By funkychicken in forum METALWORK GENERAL
    Last Post: 24th Mar 2009, 09:50 PM
