Results 1 to 2 of 2
Thread: Flywheel on horzontal Mill
11th Nov 2020, 07:15 PM #1New Member
- Oct 2020
- 2
I was on the Sandvik website today and learned an interesting fact, when using a side and face cutter on horizontal mill you get a lot of vibration when cutting because only a couple of teeth are engaged. They suggest to dampen this vibration, make as large as possibly flywheel to go on the cutter arbor, as close as possible to cutter. Will try that tomorrow and see how effective it is.
12th Nov 2020, 08:34 PM #2
Hi Countersales, Guys,
This was the rational behind the fly cutters that I have made ! Also lack of out of balance components, meaning no vibration like a conventional one. No deflection either, it takes a lot to bend a 20 mm shaft and 20 mm disc.
So yes the flywheel effect is useful !Best Regards:
Drummond 'geared flywheel' lathe approx 1912
By WCD in forum EBAY, GUMTREE, and other off forum sales sitesReplies: 1Last Post: 25th May 2020, 01:04 PM -
Facing used Toyota flywheel
By caskwarrior in forum METALWORK PROJECTSReplies: 9Last Post: 23rd Jan 2019, 03:06 PM -
Treadmill motor swap flywheel reworked.
By aametalmaster in forum METALWORK GENERALReplies: 3Last Post: 3rd Mar 2014, 09:35 PM -
old victa mower flywheel
By Swarfmaker1 in forum METALWORK GENERALReplies: 15Last Post: 18th Oct 2012, 07:52 PM -
Help with model engine flywheel
By STEAM in forum METALWORK GENERALReplies: 6Last Post: 29th Mar 2009, 10:10 PM
