Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 47
  1. #16
    Oct 2020
    Greendale Vic. Australia
    64
    Default Drill & pull?
    Or... Drill a 1mm hole in the centre of the dent, thread a motorbike cable or similar through, silver solder on a curved steel plate (shaped/domed to match the undented section) to the cable, and give it a pull. Maybe a bit of heat? -But you don't want to stretch the metal eh? Cut and remove the cable & plate, fill the hole with silver solder. Polish.
    Works with motorbike tanks.
  2. #17
    Nov 2020
    Cambridge, uk
    27
    Default copy motor bike tank method
    Quote Originally Posted by joolstacho View Post
    Thanks for your idea joolstacho. I had thought about your idea before as it happens (honest). But I wondered about filling the holes after doing the actual dent removal. There are about six or seven dents in all, close together right around the curve of the tuning slide and a bigger one eight inches from the bell. I can see it would work providing I use wet cloths as a heat sink each side of the brazing to prevent melting the soft solder which the trombone's joints are made of. But there isn't enough space to put these cloths between the holes on the tuning slide. Do you think the heat from a hole that is being brazed would melt the brazed hole(s) next to it?
  3. #18
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Brazing would definitely melt soft solder in the vicinity!
    Why not soft solder some brass wire pins to the dent and tug on those until you have the dent where you want it? It might take several lots of wire pins in different places to get a feel of how the metal moves. Once done, the remaining solder should scrape or sand and polish off back to the brass.
    If you have a look in YouTube for "Using a Stud Welder to Repair Dents". That's the same principle and you might get some idea of how the sheetmetal might respond.
    Cheers, Joe
  4. #19
    Oct 2020
    64
    Default Soft solder
    Ah right, I hadn't imagined a group of dents close together and also to a solder joint.
    Tricky little job. A little blob of soft solder would cover the 1mm hole. But also Low melting point silver solder is available.
    You can even get it in little syringes already mixed with a flux. You'd need a fine closely focused flame. There's a special coating you can paint on which 'localises' the heat too.
    Can you post a photo?
  5. #20
    Oct 2015
    melbourne
    473
    I reckon the place to start is a large steel ball (bearing?) on a string, as big as will fit, and attempt to locate it behind the dent and move it around, firmly, so it acts like a dolly. Perhaps gently tapping the edges of the dent.
    The difficulty I see is the foresee is that the Tubing is likely to be workhardened, and need annealing to make it workable.
  6. #21
    Oct 2020
    64
    But Russ, how do you get the ball back past the dent "attempt to locate it behind the dent" so you can draw it out? Or do you start with smaller balls, working your way up.
    That's the sure way of work-hardening the brass eh? And tapping around will just stretch the metal. Not what we need.
  7. #22
    Nov 2020
    Cambridge, uk
    27
    Default joolstacho
    Thanks for the ideas. I will take a photo when my granddaughter comes round next time. I don't have a phone with a camera so she will use her's.
  8. #23
    Nov 2020
    Cambridge, uk
    27
    Default ball on a string?
    Quote Originally Posted by russ57 View Post
    How would you attach a ball to a string? I suppose you could drill a hole through it and tie a know in the other side of the string. I've answered my own question!
  9. #24
    6,477
    Hi Wooly, Guys,
    This thread really belongs in metalwork general, but not to worry !
    You will have to anneal the steel ball before you can drill a hole in it, unless you can get a soft one. But drilling one that is the right size and pulling it through the tube bore with a string is a workable idea !
  10. #25
    Oct 2015
    melbourne
    473
    Put the ball in the middle of the string and thread it right through the instrument.
    Can a trombone be disassembled at all?
  11. #26
    Nov 2020
    Cambridge, uk
    27
    Default dent removal in brass
    Hi Wooly, Guys,
    Hi BaronJ. About getting soft steel balls, yes I have seen them advertised on the net but I'm not sure what sizes yet. I'm doing an experiment with a 10 mm ball to see how that goes first.
  12. #27
    Nov 2020
    Cambridge, uk
    27
    Default dent-removal-brass
    Hi Russ57. Disassemble a trombone? Yes to a degree. The sliders undo from the tuning crook-and-bell tubes and the sliders come apart from each other. Those are the main parts but the tuning crook separates from the bell tube and the mouthpiece comes out too. If you really want to unsolder various joints then the whole trombone will come to pieces. But the bell and about 24 inches of tube behind it are all made in one piece. About putting the ball in the middle of the string and threading it so you can then pull it both ways, yes of course. I should have known.
  13. #28
    Nov 2020
    Cambridge, uk
    27
    Hi Guys. While I was thinking through all the ideas you have sent, I noticed that the water drain operating lever, called a water key, wobbles so much that the felt sealing pad on its end sometimes misses the nozzle and therefore fails to seal the trombone tube. When left like this the trombone doesn't play very good and you have to fiddle with the water key to get it to seal. If you're at home, messing about with the 'bone this doesn't matter but if you're on stage it can mess up your entry to the music and make you start late or at least to miss a few bars. So I started to investigate why the key wobbles and found that the hole in the brass water key had worn very much oversize. Then, instead of filling the hole with epoxy resin and drilling it out to the correct size, a quick fix, I tried to force a bush into it. Guess what happened. Yes, the water key split in two. so now I am distracted from removing dents to fixing the water key. So I won't be writing about dent removal for a while.
  14. #29
    Nov 2020
    Cambridge, uk
    27
    Quote Originally Posted by woolyhead View Post
    Well that was quick. Here I am again. Hopefully my pictures are attached.
  15. #30
    6,477
    Hi Wooly,
    Can you solder a pair of small brass washers to the inside of the lever ?
  1. what rods for thin brass to brass ??
    By Mathuranatha in forum WELDING
    Last Post: 23rd Nov 2020, 08:17 PM
  2. What's the best way to dent this back?
    By qwe7410 in forum METALWORK GENERAL
    Last Post: 26th Jun 2017, 09:40 PM
  3. VICTORIA Brass Flat Bar Assorted Sizes & 1/4" SWB Threaded Rod & 260 Carbide Brass Sheet
    By thumbsucker in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 18th Mar 2013, 03:36 PM
  4. Key Removal
    By tongleh in forum METALWORK GENERAL
    Last Post: 15th Nov 2012, 01:48 PM
  5. Spindle removal
    By Buncha in forum THE HERCUS AREA
    Last Post: 14th Jan 2009, 10:33 PM
