Page 4 of 4 FirstFirst 1234
Results 46 to 47 of 47
  1. #46
    Nov 2020
    Cambridge, uk
    27
    Quote Originally Posted by woolyhead View Post
    Oh yes. I agree, this is brilliant. Thanks for pointing it out BaronJ. It's certainly worth remembering for the future.
    Actually, I am wondering how thick you reckon the steel rod is and is it mild steel, stainless or spring steel of some sort? I've got a tenor sax with a few dents in it so I may buy a rod of steel and try this technique out for myself. The length looks to me like it's about 300 mm . And the diameter of the rod looks like 8 mm or so. What do you think Baron.J?
  2. #47
    6,476
    From looking at the video the rod looks to be 8 or 10 mm diameter. I wouldn't have thought it to be anything special like spring steel. I agree with you about the length, but I don't think it would be critical, since you could just alter the position where it is clamped.
    I did have a play with an 18" inch length of 3/8" rod and tapped it with a hammer handle. The vibration gets more violent the nearer the free end. Get a piece of rod and try it. You might find the creating of the curved end more difficult since you might have to forge it to get the bend properly shaped. But it does twang like a guitar string.
  1. what rods for thin brass to brass ??
    By Mathuranatha in forum WELDING
    Last Post: 23rd Nov 2020, 08:17 PM
  2. What's the best way to dent this back?
    By qwe7410 in forum METALWORK GENERAL
    Last Post: 26th Jun 2017, 09:40 PM
  3. VICTORIA Brass Flat Bar Assorted Sizes & 1/4" SWB Threaded Rod & 260 Carbide Brass Sheet
    By thumbsucker in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 18th Mar 2013, 03:36 PM
  4. Key Removal
    By tongleh in forum METALWORK GENERAL
    Last Post: 15th Nov 2012, 01:48 PM
  5. Spindle removal
    By Buncha in forum THE HERCUS AREA
    Last Post: 14th Jan 2009, 10:33 PM
